Console / dash part help
lamrith
Can anyone point me to the part number or online breakdown/parts list for the center column of 2013 sho dash?
Looking specifically for the panel pictured with the tc, park assist, cig lighter ports.
Sent from my SAMSUNG-SM-G935A using Tapatalk
That looks like it.  I think the TC/PA button module is present on all cars, just have to mode the switches?
OUCH, $205.  Not worth it for the plan had in mind.
Thanks Hawkeye!
My car doesn't have park assist, the left side of that button isn't labeled, and doesn't move.  I do have the traction control button.
I considered mounting my meth LED there, but it was too spendy for me to replace it.
I have both.  I was looking to buy one to install more switches in, so I had the original one if want to return to stock later.  Looking for plan B now. :-p
Id suggest a piece of aluminum, you can make it fit, cutouts for the current objects, and add what you need. Alternatively, if you can be patient you can find a NON SHO (or an SHO if you get lucky) in a junkyard/for parts, and pull the one from that.
That is exactly where I mounted my LEDS for the meth kit. Worked really well...
I do wish I had mounted them somewhere more in eye view.. however, on the Alky kit, the relays that kit on and off the meth pump are loud enough I don't need to look at the lights to know if it's spraying :-)
Yeah I wanted to mount an on/off switch as well as LED's down there, but also wanted easy way to return to stock.  I will look artound for other hidden mounting locations.
So, the little bacon dispenser on the right below the steering wheel and the same piece on the other side are small simple pieces to remove.. might be a decent spot? You could invest into a gauge pod too...
