"How- To" 2010-2012 Brake Master Cylinder and Brake Booster Retrofit
EcoPowerParts said:
I think I need to do this ASAP! :)
Sorry to resurrect an old one but this is a pretty common problem with a LOT of 2010-2012 SHOs.
Mike, did you ever get around to doing the swap? I am going to attempt it once things warm up in the spring. I just want to make sure all of the components fit and last for years.
So I was studying this as I need to complete the swap on the Lincoln.
It appears the the PN for the booster may have changed.
For the MKS and SHO application, Rock Auto is showing the PN as BRB137
Correct FoMoCo! It looks like Ford Part No DG1Z-2005-B is replaced by DG1Z-2005-D- BRB127- BRB137-
Best of luck.  Z
Booster Assy - Brake
When Replacing This Component, 2L523 Has To Be Replaced
$94.81
https://www.fordpartsgiant.com/parts/ford-booster-asy-brake_dg1z-2005-b.html?Vin=1FAHP2KT5DG183206&Filter=()&Location=pd:,
https://www.rockauto.com/en/moreinfo.php?pk=6514950&jsn=416https://www.rockauto.com/en/moreinfo.php?pk=6514950&jsn=416
Bringing back an old thread..
Owned my 2012 Ford Taurus SHO for a few years now and just heard about the 10-12 master cylinder and booster retrofit. I just installed parts from a 15 SHO and currently am having a vacuum leak around the master cylinder and brake booster connection. Is there a gasket that mates the two parts? Also after bench bleeding and bleeding all four calipers I'm still having a squishy pedal until about halfway down.
Any insight would be much appreciated.
Did you install new, oem parts or ...?
there IS a seal between the MC and booster that if compromised will leak brake fluid into the booster, not sure about a vacuum leak tho.
did you bleed the calipers in sequence, with fluid topped off in the reservoir/cap open?  have you tried bleeding the abs yet?
I purchased a used oem booster and master cylinder off of a parts car. Originally, i was missing the gasket that went between the booster and master but i've since located one. It looks like i had some air in the ABS module because it several hours of bench bleeding and bleeding each caliper to firm up the pedal. Braking has definitely improved over the 10-12 setup.
