Coops Blown 416 TBSS
Getting there...but it wont be done before I head back to work next week.  The good news is it should be done for the fall Kanc cruise - and if Im home Ill be there.
Wrapped all the coolant lines, breather lines etc. in tech flex.  Makes the engine bay look 100x better IMHO.  Im normally more function over form but I figured while it was all out, what the hell.
Ran the return lines from the rail to the regulator and mounted the regulator too.
Jay started the intake.
Dont even have to spit on this one to get my fist in.
Should be starting her up next week.  Its been a bit of a pain in the ass as work has been crazy and I travel for my job.  I thought we were going to have it up and running the end of last month but I ended up getting sent to Korea for all of November.
Anyway, here are a few updated shots.
Wiring the Aeromotive Billet Controller.
Setrab trans cooler.
Getting close to buttoning it up.
Some fresh fluids.
And some fresh fluids for my X.
This next post is just copied from TBSSOwners - but basically to sum it up we had DSX Tuning in St. Louis build this custom MAP sensor.
I just wanted to throw this out there to share.  We're wrapping up my 416/jack shaft 2300 build now and we had run into some problems with the MAP sensor.  I wanted to tune SD for a few reasons and we hard built the intake without a MAF port.
As we neared wrapping up the build we realized that the position of the sensor port on the LC32 made mounting a MAP sensor a bit tricky, especially on a build where we would be relying solely on the MAP signal and fitment/seal would be critical.
My original plan was to run a LS2 style sensor I had bought from Dave at DSX Tuning months ago.  I hadn't really bothered to check fitment as it wasn't on the top of my list.  I made a small bracket to hold the LS2 style sensor in the port but wasn't happy with it and soon noticed that the port size was actually bigger.
Anyway,  I contacted Dave and told him what I needed, essentially a mirrored image of an LS9 sensor so the wiring harness/connector faced away from the cog drive instead of into it.
The space is super tight so using my artistic abilities I traced the port/mounting area and took some measurements for Dave.
Center bore/center bore, diameter, bolt size etc we're all sent to Dave.
A few days later he sends me these photos:
And after another couple of days it showed up at my doorstep!!
I was a bit nervous of my measurements, but as it turned out they were spot on.
Dave's craftsmanship is second to none, this sensor look and fits exactly like you'd expect an OEM sensor to.  I should also point out that Dave informed me that the LS9 sensor would not work for me either as the 06 ECU will only support 2.5bar, and does not allow for negative scaling.  This certainly would have been another headache for me as I did not know this.
Thanks a ton for the help Dave!
Hung out with        [MENTION=310]OVRBST[/MENTION] and        [MENTION=118]EviL8[/MENTION] today and finally made some music.
TBSS with blown 416
Im pretty sure any problem you can have with a build like this we've run into, but today defiantly got me pumped up again to wrap this baby up!
I wish I had a way of accurately capturing the noises this thing makes.  With the cutouts closed, standing behind the truck, you can feel the rumble in your chest.  I don't honestly think someone could hear this thing and not have a $hit eating grin come across their face.
Edit - couldn't figure out how to embed a photobucket video so I stuck it up on YouTube.
Your lightly modded TBSS sounds GOOD!  11 second on street tires, that MUST be fun!  I think we have a Ford Expedition on here that runs in that range as well.
Equal length headers?  Underdrive and/or lightweight pulleys?  Any mods to the 4L70E trans (known power handling limits)?  How much boost are you planning to run?
10% OD on the crank and a 2.9" front blower pulley.  The rear cog drive is 1:1.  It should yield about 16lbs of boost on the 416.
Trans is a Phoenix 4l80e now, it will take everything we can throw at it, the weak link will be the front diff.  Unfortunatly there are no upgrades for the diff so well see how long she lasts.  I think it will be fine with street tires but when we go to drag radials I'll likely grenade it!
I've owned several GM products and have my reasons for not being a GM fan, but between Mike's V and your TBSS, or "van" as you call it, I'm having a hard time not poking around on AutoTrader for a fun 2nd vehicle. Much respect for the amount of time and effort you've put into the TBSS. I think any car guy, regardless of brand preference, can acknowledge that much!
Awesome build!
Great job, looking forward to seeing what kind of times you get out of it!
I'm being talked into doing Pro-EFI and TT on my V this fall, we'll see if it happens! :)
