peppelepugh
Member
Just had my brake booster replaced under warranty 2 weeks ago (had a bad seal and squeaked A LOT). Well right after, my brake lights would be stuck ON and my cruise control would cut off while driving when I hit a bump every now and again (since the pedal moved enough to trip the switch). After some investigation (didn't take much) that the Brake Pedal Switch (SW5955) was being tripped with the brake pedal at rest because it wasn't going back far enough to close the circuit. It would be perfectly fine if I lifted the brake pedal with my foot, just enough to trip the switch. So many times, my brake lights for a WHILE, causing a burnt out bulb...
So I take it back in, explain what was going on, and got my call back about it. Their mechanic says that it was NOT caused by replacing the booster and would be a new warranty claim.... Weird, because everything was PERFECTLY FINE before they touched it. I asked the service manager why and explained to him how the brake pedal is not "resting" at the same position it was before causing all the erratic behavior. He said his tech told him replacing the booster has no affect on the brake switch, meaning it's not on that same warranty claim. He also told me since I have a brake light out explains why my cruise control does not work. When I clearly told him that it cuts out randomly when I hit bumps. They also don't like LED tail light bulbs, because they said everything isn't working properly because of the LED brake light and tail light and that 1 of them is out. Weird, it has worked for over 2 years!!! He tried telling me that they are willing to replace all of them with OEM bulbs... I'm debating about replacing them all, then taking them for a test drive to prove them wrong and ask them what they would like to do for me?
I'm pretty sure I don't have "SUCKER" written on my forehead, do I?
I'm debating about taking this up with a Ford Rep...
Any thoughts everyone?
