black99lightning
I want mine to sound like a GN. I've heard a couple that have that sound.
yowen said:This is why I am starting with catless downpipes and from there I can see how much sound I want to add and how. From there there are a lot of things I can change, the cat, the resonator, the muffler, the whole system.
Needmoreboost said:The Corsa system is actually not a cat back because it removes this third cat. But, it's also a LOT of moola. Bottom line, a good tune makes 95% of the power versus anything else you can do outside of meth or upgraded turbs.
I didn't get an order for hot pipes, did I miss something?SwampRat said:Needmoreboost said:I removed only the third cat. Sound level went up maybe 5-8% tops. I can though hear the turbo's spool down now at start up. Pretty cool. The car feels like it does spool a little faster. The Corsa system is actually not a cat back because it removes this third cat. But, it's also a LOT of moola. Bottom line, a good tune makes 95% of the power versus anything else you can do outside of meth or upgraded turbs.
Yes $ for $ a tune is the best bang for the buck , But if you want more power than what a base tune with mostly stock intake / exhaust can provide you Need to improve on the bottle necks in the rest of the system .
The second best improvement over a tune is Better Downpipes .
Some Folks just Map the way to where they want to end up differently .
MY first Mod was the Corsa exhaust then AirAid then the BIG one .... TCE/Wilwood Brakes .
PPE HotPipes with TIal BOV are ordered and on the way .
Yup, he PM'd me.BiGMaC said:Mike... I sold SW the ones I bought from you when you were returning the preV ride to stock.
4DRHTRD said:Yup, he PM'd me.BiGMaC said:Mike... I sold SW the ones I bought from you when you were returning the preV ride to stock.
I just let Jeremy know to russle up a new Tial BoV to replace the one he used from the pipes and I need to get an inventory to make sure we're not missing any silicone bits or clamps.
4DRHTRD said:I didn't get an order for hot pipes, did I miss something?
SHOdded said:Maybe when SR gets his SHO back & replaces the injectors, a flow test (actual vs commanded) can be done to compare OEM vs the aftermarket units.
DJE624 said:I think, as Tom surmised, that the tunes run a little rich to compensate for AFR at high rpms. I had about 14.7 AFR while cruising on the interstate last I checked. Which is fine. I'll be sticking with stock turbos. I'm just going to make the most I can from the stock fuel system.
thatsmrgimp2u said:How long did the install take for the downpipe portion? I'm going to have the car in a shop to have a drain installed in the PTU, if its only an hour or so I may just pay to have them installed vs doing it myself. Thanks!
thatsmrgimp2u said:I'm going to have the car in a shop to have a drain installed in the PTU.
BiGMaC said:DJE624 said:I think, as Tom surmised, that the tunes run a little rich to compensate for AFR at high rpms. I had about 14.7 AFR while cruising on the interstate last I checked. Which is fine. I'll be sticking with stock turbos. I'm just going to make the most I can from the stock fuel system.
Great info Dave. Thanks! :thumb:
If memory serves an AFR of 14.7 is exactly what the EPA requirements are.
