Downpipe install
Brandon2525
Hey guys doing the down pipe install all the bolts came out of the rear turbo but two of the studs are stuck in the front and won't come out any ideas?
Did you spray some PB Blaster liberally on the bolts and let it soak for a while prior before removal of the bolts?
Im not sure what u mean...bolts and studs are different...did u have bolts or studs?...leave the studs that are in and any that came out just put them back in..use nuts and studs
Sounds like you should order upgraded turbos and knock that install out now too :)
