autobahn terror
Hello ALL,
Long time Lurker, First time Posting. So...Lets have some fun with this thread. Fairly well modded 2014 PP SHO, with more mods to come, Rolling down the German AutoBahn at 170 MPH, and then..BOOM!!! I thought it was a Blowout, turns out it was the Driveshaft, or as Ford calls it the "propeller shaft", from PTU to Rear Diff.
Still trying to figure out exactly what happened, and what the total amount of damage is, But it isnt as bad as it could have been. Drive Shaft Snapped in half, is the worst part so far, not sure if the PTU is damaged. My Corsa Exhaust took a Beating, so did the under body. My thinking is there are 3 possible reasons for failure:
1: Excessive Speed, 170 MPH is "Flying", to Quote Mike over at EcoPowerParts, and RPMs of the Drive shaft are approaching Ludicrous. If the Carrier Bearing in the "loop", failed, could have cause a drag on the shaft, creating imbalance which tore it in half.
2: PTU failure, This One is a maybe, but since me and Good friend Yanked out the Drive Shaft and Drove the car with out any issues in FWD only "mode", with no Grinding, crunching, or other noticeable hicups other than Excessive Torq steer, I am Fairly Confident its not the PTU, all though, until a new drive shaft is put in wont know for sure.
3: Wind! this one is also unlikely, but plausible. There is a heat Blanket that is located just above the location of the failure, at 170, I believe it possible that the blanket can be pulled into the shaft if a plastic grommet failed, pulled into the spinning shaft and this could cause failure if it got hung up, or cause a drag leading to imbalance...
4: Defect, which is the obvious one, especially when combined with the others listed. My mechanic buddy, says the carrier bearing is the most likely.
NOW, what does this mean for you guys? Probably not much, unless your in Germany with me and hitting the autobahn hard like I do. Unless of course You want the details of the Aftermarket drive shaft I plan on sourcing for your own cars... I am still in the VERY early stages of getting this sorted out, and I will Keep you all posted
http://www.shoforum.com/index.php?threads/drive-shaft-catistrophic-failure.134806/#post-1469301
so far i have found that most mustang guys doing drive line swaps, upgrades, are deleting their carrier bearings. i phoned over to inland empire driveline, and they said they can build it no problem. the issues are i dont have any good measurements to do so. AND... i plan on doing a megan coilover swap soon, which 'could' change the geometry. im looking at doing somthing similar to this MP-06 Custom Aluminum Driveshafts 4" Aluminum shaft to replace the heavy stock two piece shaft. No adapter is required. $746.75 https://www.iedls.com. these guys do some serious work...
need to figure out the shaft rpm at 200mph in 6th gear, overdrive...
Questions??? Comments???
