E85 or 100 octane
Wish I wasn't stranded in the middle of the US. All the cool stuff goes on without me hah.
It would be awesome to get Aero force to add that in. Since I'd look like a idiot testing fuel at the station before I fill up, haha.
I can tell by my fuel trims that the E85 here is extremely consistent.
I'm just going to wait till I'm tuned and the downpipe and cutout are on the car.
My suspicion is I will be at the point that going further will probably cause things to start going boom.
I want to see how much safe power can be made with basic bolt ons and tune with the corn then I'm probably done for a while with he exception of some lightweight wheels.
2013 and up SHO got the upgrade fuel pump correct? I was searching for a part number last night for new fuel pump
4DRHTRD said:
wasinger3000 said:
Found out the car won't start on e30 with the stock tune... hah.
Do you have a 3 bar sensor, cause it won't start with that installed either... :)
Yeah that too. Hah. So I guess I better keep that 2 bar in the trunk just in case.... This ecm is such a baby!
Also tested some 91 fuel that I filled up with last night. It has 0% ethanol in it. Which is weird cause its the same price as 91 with 10%. Not sure if that's good or bad since they use a lower grade base to make the 91 with 10% maybe this is better since it's a true 91? Idk. I guess I need some way to test octane.
Something is not right there. I've been well over 30 with no issues. Even At that blend there's plenty of pump gas to get the party started.
The intercept and slope is different on the 2 bar vs the 3 bar, it's getting different pressure readings than actual readings, that's the problem. :)
