SHOdded said:
can you post the *.fsl logfile anyway? We can look at it on the smartphone/tablet at least
Ha, silly me. That should work. I'll attach it via zip folder.
One thing I think I'll do is get a graph reading of me sprinting on the highway or so. Once I started the FORScan logging, I continued to drag without turning off the car. Any down periods is due to waiting in line.
I just want to find out the reason for massive heat soak upon acceleration attempt. If the Intercooler itself was poor, it wouldn't recover from such high heat so fast upon finishing the run. My Fusion was like that on stock intercooler because that thing was atrocious to heat soak, and it would never recover. This seems...to be temporary heat trapping issue during acceleration from 0.
Also...since you'll see the full log, I actually did have 4 attempts at the strip run. I just omitted one because I goofed and red lighted at the start (didn't trigger pre-stage light correctly). But the car recovers very quickly which is the impressive part.
AnotherGreenFusion said:
Thanks for getting some stock times, not bad at all but like with the Fusion sport I can't help but think it can't do a bit better even as it stands now but it could be that stock tune really getting in the way as you are seeing. Would be interesting to see a stock like tune with the AGS and torque limitations removed just to see what it could do from the factory without the leash.
Nice to know all I have done puts my little 2.0 within spitting distance of these monsters at least when they are stock ;-)
Heh definitely would never get cocky about buying a new stock tune car. So much more factors than just raw horsepower and torque, and even then, Momma ECU isn't going to allow any of that hoon driving easily.
Just goes to show how crazy conservative factory tunes are, and why tuning is such an effective impact on performance customization alone. I already expected this, despite the 400 HP/TQ rating. There's a huge catch behind it (and for any other non-performance minded car) since these cars have to be tuned for EPA and any kind of driver. It's not going to allow such power unless you're in a highway drive situation.
A Lincoln article mentioned "It's not in your face power". So the tune is clearly designed with only highway in mind for maximum power potential, or tracking style driving. It's still good on the street though, just not green light hot rod like many performance folks would like it to be when they hear "400 HP/TQ". I can only expect the same thing to apply to the Fusion Sport, which is why some folks seem disappointed in it but I think its being measured unrealistically and without realization just how many "nannies" are in place. If you want that raw responsibility of performance like old cars, a tune will be absolutely necessary.
The MKZ has the parts to perform strongly, but doesn't matter if the tune itself is made for getting groceries, going places, and cruising the highway. The electronic throttle body, torque management, all that computer stuff intercepts and restricts any form of performance racing or drag running with an iron shackle. Hence why before I even think about bolt on mods to upgrade, I have to unleash its real potential and learn from it first.
The best time to feel this MKZ's full pony power is to put it into Sport Gear while going 20-40 MPH and punch it hard, because oh man...it's pure performance ecstasy then.
