Fan running too high?
FracaSHO
I have a 14 F150 EcoBoost FX4.  The fan kicks on perfectly normal.  But when it's really hot, 85 to 90 and humid, it gets really loud. And it only seems to go on in the sun, or when sitting idle for longer than a few minutes. Is this normal?  It almost seems like there's 2 fan speeds. Thanks.
Brad
Former SHO Owner
Ecobooster 4 Life
Most electric fans have several "stages" that they can go in to meet the demand to cool.
I've noticed the same thing lately when on max ac.
I believe I had max ac going while the fan hits high gear. Sound normal. It's just like jet engine loud. Thanks guys. 👍🏼
Brad
Former SHO Owner
Ecobooster 4 Life
The secondary fans can certainly get a bit TO loud (Warp Speed)...shutoff the a/c and in matter of seconds its back to normal nice and quiet.  Z
Funnily enough the secondary fan is loud on the Fusion, whidper quiet on the Edge.  Go figure.  Maybe the SHO F150 fans are more powerful.
SHOdded said:
Funnily enough the secondary fan is loud on the Fusion, whisper quiet on the Edge.  Go figure.  Maybe the SHO F150 fans are more powerful.
I will try to post a video for ya....sure go on quick at 100 deg,let me know.  Z
That'd be cool LOL.  Most of the sound I usually hear is when I change to or from the MAX A/C setting (the hiss).  I will have to check to make sure the secondary fan is working, the duty cycle says it is.
I always have the a/c set to LOW with NO max a/c set just normal a/c on with re-circulation mode to be the best effective setting with colder air.....new MC cabin filter and found the the a/c level to be roughly 42 degrees which is more than sufficient on a 100 degree day.....will post a video later with the secondary fans on (warp mode)for ya later.  Z
There are fan speed tables for ac/coolant/and trans oil temp
Ac fan speed is based on ac head pressure vs ambient temps
Coolant temp fan speed is based on coolant temp vs ambient temps
Trans temp fans speed is based on trans oil temp vs ambient air temps
There is also a desired coolant temp setting that is independent of the other tables
The values in the tables for fan speed are a perfentage of max allowed fan speed which is 7000 for most strategies ive seen and i think its rpm
So for the table for coolant vs air temp is may read like this...at 190 coolant and 90 air temp fan is 50%
At 220 coolant and 90 air you get 100% fan speed
At 150 coolant and 110 air temp you get 0% fan speed because you dont need the fan yet
Strangely the old sho's and new are different
