I do, I have the log from this run. What is your email address?AJP turbo said:That is awesome I'm gunning for you LOL do you happen to have any data logs you would like to share I'd love to see them .....kick ass time
This tune has been on the car since Sunday. Only 1 revision on it. No down pipes, just e20, 3 bar, and k&n drop in.AJP turbo said:f8tlsho how mature was the tune when you ran? How long was the tune on the car when you ran? No downpipes either?
That is a solid time I think for that boost..Makes me optimistic of times I may run. Your desired TIP was about 203kpa. So you were targeting around 15psi throughout the rev range and gears through the run. That's exactly what I've been running while I've been working on some things....I thought I would have to run more than that to run that kind of time.....You didn't have any knock...Your boost spikes on upshifts but that's an unavoidable condition if the throttle stays open, which it did....The stock tune will regulate that with the throttle. Your boost falls off a bit near redline but it's not bad at all, I've seen worse. You have to tell it when and where to add wastegate duty cycle.
Anyway nice run and thanks for the datalog...You basically log the same stuff I do...I've been wanting to see a nice time with no meth and data with items similar to what I would log so that fit the bill near perfect
Cecil county dragway in mdFoMoCoSHO said:@ f8tlSHO
What track was that?
Normally bjs wholesale club, but this was from sheetz convenience store.SHOdded said:Helps to have good DA at the trackCecil County is famous for that!
Rocketship there, f8tlSHO, great results! Where do you normally fuel up from? Shell, Exxon, ...?
:thumb: once again, well done!f8tlSHO said:Normally bjs wholesale club, but this was from sheetz convenience store.
Congrats on your new PB. Z :thumb:f8tlSHO said:Da was really low, low hundreds to negative hundreds depending on time
Sent from my iPhone
Yes, 33 lbsFoMoCoSHO said:@ f8tlSHO
Dd you adjust your tire pressures?
Hopefully this new tune he sent me is the same as yours, i will know this saturday haha.BMC10SEC50 said:12.41@111.....no meth, no E85, no race gas, just a badass 93 Torrie tune!
Yup I know what I meant is how aggressive it is. I ran a 12.6@109 so close enoughBMC10SEC50 said:He wouldn't send you my tune. This is the difference between data logging and building a generic tune on a dyno. All cars are different and all areas have different weather so my tune is my "custom" tune built from the logs. Your tune will be custom to your car in your weather conditions. This is one reason I left the other guy to go with Torrie.
17 revisions, yes I am maxed out. At this point I am trying to add some e85 (3 gallons to a full tank) and need to send him a log this weekend.BMC10SEC50 said:Good pass- how many times has he tweaked your tune? Are you maxed out?
