Flex ran a 12.419 @ 112.43 MPH at Fontana
Gray Brick said:
3529 DA today... 90 degrees
Hopefully Brad can help push me into the 11's.
Impressive! Hope I can get my Flex to the track next month!
Looks like you can improve on your 60'
Sent from my SM-N960U using Tapatalk
I don't have any hard numbers for the intercooler since I am running meth.
I do know that it doesn't restrict the flow like the stock unit.
Bummer....
Just blew my head gasket at cylinder #5.
160,000 miles on the odometer.
Wondering if I should fix the gasket or replace/rebuild short block.
Any suggestions??? Not sure if the water pump will last much longer with this mileage.
:o  Rebuild sounds like a better option, but replace at the very least.  If putting in a nused engine, may want to do the timing/water pump anyway while out of the engine bay.
Gray Brick said:
Bummer....
Dang just saw this, sorry to hear :( You were getting close to taking out my old record. :)
