Getting my PTU flushed today
jcl78
Hello All,
So I finally scheduled my PTU flush for today with my mechanic (same one that changed my master cylinder) so we shall see how it goes. I am asking him to save the old fluid or take a picture of it so we can add it to the archives here. I am right at 38K miles, so we shall see just how bad it is. This is definitely good piece of mind for keeping the PTU in top shape.
Updates to follow...
BiGMaC said:
Can the pics also show the opened PTU with everything in situ?
SHOdded said:
Do you know how he plans to flush the PTU fluid?
Ooooh… hadn't thought of that Manu… is the dealer gonna suck out the fluid and refill, …or... take it off… open it… clean it… fill it… then reinstall?
He will be sucking out the old and putting new in, so no dissasembly pics :) I guess it is not a true flush.
I am about to have this done with my next scheduled maintenance, what is the forum's recommended replacement fluid? I am a fan of Amsoil products.
Royal Purple is the most common replacement brand used by forum members, 1 or 2 folks talked about going at it with AMSOIL, don't know how they are faring so far.
Ok, back with news, yes indeed the old gear lube is nasty sludge. My mechanic was shocked at two things, the condition of the lube at only 38K miles, and the very small amount of fluid the PTU holds. He did the procedure twice, and he still recommends in a month or so to bring it back and have it done one more time to get the remaining sludge out. They did provide me with a sample of the used fluid, I will snap a few pics here soon and post it. I would recommend every 30K miles at most for PTU fluid change (20K if you track the car or drive hard).
Let me guess - consistency of pudding? Lol
Chalk up another who thinks the capacity of fluid housed in the PTU is utterly insane.
Going to perform this little procedure pretty soon myself. I'm at 12.5K miles now. Thinking about making 15K my interval.
I would like to see how fluid is holding up in 2013+ PP cars as the PTU is water cooled. I have for a while now thought of ways to increase capacity and add cooling to the PTU in my car. And I believe it could be done, with the fitment of a drain plug would give a way to add a cooler. Which would add a little more capacity is just doing that, but what I visualize is putting on rear dif cooler on the PTU. Which consists of a thermostatically controlled oil pump and cooler. Other simpler alternatives to test is better oils and friction modifiers. I have read about product recently that I have thought about giving a try. But unfortunately having the time and funds and priority for me lately I am lacking. Plus injuring my hand recently doesn't help either.
From looking diagrams on fordparts.com on the 2013 pp it looks like it may actually have drain plug. I don't see a fill plug, but it could be filled thru breather tube or thru the drain.
68_GT, looking forward to your drain-and-fill results!
Crash, sorry to hear about your hand, hope it goes to 110% soon!
any links to completing that job ? Wonder if I can do it on ramps in my driveway ? need some fresh Mobil 1 while I'm at it.
Thanks shodded! Sorry 68 no how-to I am aware for this yet. But can't hurt to get under there and have a look.
http://www.ecoboostperformanceforum.com/index.php?topic=1706.0
"How-To" PTU Fluid Exchange - glock-coma
2010 RCM non PP
K&N panel filter
sp534 @ 30
unleashed 93 performance+boost
more to come.....
Yea, im also doing this very soon. At 43k now... got a qt of Red Line fluid, just need to get the mightyvac or take to the dealer, will prob do rdu at same time,.
2010 RCM non PP
K&N panel filter
sp534 @ 30
more to come.....
This doesn't apply for 2013+ PP cars.
Ok, here is a crappy photo, but you get the gist...
As you can see, the sludge is still stuck in the bottom of the Gatorade bottle, and it took awhile to slide down to the side when I took the pic. It is not as bad as some I have seen on here, but it is not good.
I have noticed a few things, and it may be in my head... but the car seems quieter overall, and as one other poster on this board said... more "free wheeling" with less resistance down hills and less throttle input needed to keep constant speed.
I am stunned!  Thanks for the pic jcl!  It certainly looks like the oil was failing.
Since the PTU was not removed for cleaning, can you describe the flush process in a little more detail...cleaning agent... number of times flushed....how much was used?
Sorry if I missed it, but what was the charge?
