SHOdded said:Hey AJ! Wanted to say thanks for the work on this issue, I was able to use this information to help someone over on SHOforum, all straightened out nowThanks also to scott for bringing this topic to light, and FoMoCo for assisting with the analysis/asking the right questions. :thumb:
LOL, that would be me over that SHOforum. Although, unfortunately I am still having an issue. I talked to Torrie and he said that I am having fuel pressures issues. However, looking at Scott's logs, mine are almost identical. I am going to go ahead and attach the two logs I have if you want to compare or have any thoughts...
My first tune based on MAP sensor I was pushing 20psi.. load was over 2.0... ambient air was around 50F. Torrie has dropped the boost a bit since then as the revisions are progressing...
Rolling-WOT-93B1-Modified - This is the problematic run, its gotten a bit better with each revision. I get knock and then fuel pressure drops, and the TB closes up a bit. This was a run from around 60mph to 80mph. I can duplicate this every time I do it.
WOT-from-Stop-93B1-Modified - This the cleanest WOT from a stop that I have. No knock, no TB closing, no MAJOR fuel drop.
What bothers me is that Torrie thinks I need to look at troubleshooting my fuel system... either fuel pump, module, or HPFP... but looking at Scotts logs seems to be similar, did Scott replace any of those parts?
