HELP.... Need Key on power
ddlopes
I need help finding a fuse in the fuse box under the hood on the drivers side that is key on power. Thanks for any help....
I'm sure it's different on the SHO, but on my XSport, I used a multimeter to find a switched fuse slot that wasn't being used, then used a fuse tap to tap into it.  If you don't have a multimeter, a cheap test light will work as well.
    Here are some wiring diagrams which can be useful.  Z      12volts yellow/red (5A) + ignition switch, black 7 pin plug, pin 4
Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash.
Starter blue/white + ignition switch, black 7 pin plug, pin 7
Second Starter N/A
Ignition white/orange + ignition switch, black 7 pin plug, pin 1
Second Ignition N/A
Third Ignition N/A
Accessory purple/green + ignition switch, black 7 pin plug, pin 6
Second Accessory N/A
Keysense blue/gray + ignition switch, black 7 pin plug, pin 5
Power Lock blue/green (test with pass sw on models w/memory) - BCM, black 26 pin plug (C), pin 6
Power Unlock yellow/purple (test with pass sw on models w/mem) - BCM, black 26 pin plug (C), pin 8
Lock Motor gray/brown 5 wire driver kick, harness to rear
Unlock Motor blue/green (models without memory) 5 wire driver kick, door harness
Notes: On models with memory, it is blue/green (5 wire) at the Driver Door Module, black 24 pin plug, pin 10.
Parking Lights+ yellow/blue + BCM, gray 10 pin plug (E), pin 6
Parking Lights- gray - headlight switch, gray 10 pin plug, pin 2
Notes: May need to interrupt the headlight switch ground wire when triggering this wire. It is black/white at the headlight switch, gray 10 pin plug, pin 3. See Tech Doc 1096 for wiring information.
Hazards brown/yellow - BCM, black 52 pin plug (B), pin 32
Turn Signal(L) blue/green (F); gray/orange (R) + BCM, brown 26 pin plug (F), pin 8; black 26 pin plug (C), pin 14
Turn Signal(R) yellow/purple (F); green/orange (R) + BCM, brown 26 pin plug (F), pin 7; black 26 pin plug (C), pin 15
Reverse Light blue/white + BCM, white 32 pin plug (D), pin 13
Door Trigger green/purple - N.C. BCM, black 26 pin plug (C), pin 9
Dome Supervision gray/purple (dome lamp); purple (puddle lamp) + BCM, gray 12 pin plug (A), pin 1; black 26 pin plug (C), pin 1
Trunk/Hatch Pin gray/orange - N.C. BCM, black 26 pin plug (C), pin 19
Hood Pin blue/orange - N.C. BCM, brown 26 pin plug (F), pin 2
Trunk/Hatch Release brown/yellow - release switch, blk 6 pin plg, pin 6 or BCM, blk 26 pin plg (C), pin 23
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm see disarm no unlock
Disarm No Unlock Transponder and ignition
Tachometer grn/blu, gry/yel, pur/gry, yel/org, brn, or grn/wh ac any fuel injector, white 2 pin plug, pin 1 (3.5L/3.7L TIVCT)
Notes: On 2.0L GTDI models, the fuel injector wires are green/blue, gray/yellow, purple/gray, or yellow/orange at the lower front of the engine, black 16 pin plug, pin 1, 4, 5, or 6.
On 3.5L GTDI models, the fuel injector 4-6 wires are yellow/orange, brown, or green/white at the top center of the engine, black 12 pin plug, pin 2, 3, or 4.
Wait to start N/A
Brake Wire purple/white + brake switch or BCM, black 52 pin plug (B), pin 28
Parking Brake white/purple - parking brake switch or BCM, black 26 pin plug (C), pin 7
Horn Trigger purple/green - horn switch or BCM, black 52 pin plug (B), pin 33
Memory Seat 1 purple/white - driver kick, harness to rear
Memory Seat 2 yellow - driver kick, harness to rear
Memory Seat 3 N/A -
Interface Modules: Not Available
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery WHITE/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Power Antenna WHITE (+) RADIO HARNESS
Amp Turn On VIOLET/RED (+) RADIO HARNESS
Amp Location LOCATED BEHIND TRIM ON LEFT SIDE OF TRUNK
  THERE IS A SONY DSP MODULE AND A SEPERATE AUDIO AMPLFIER NEXT TO IT - BOTH PROVIDE AUDIO SIGNAL TO THE SPEAKERS.
Steering Cntrls OPTIONAL
Speed Cntrl YES
Radio Security YES - VIN CODED
Security
Battery BLUE/RED (+) IGNITION SWITCH HARNESS
Ignition 1 GREEN/VIOLET (+) IGNITION SWITCH HARNESS
Starter 1 BLUE/WHITE (+) IGNITION SWITCH HARNESS
All Door Trigger GRAY/VIOLET (+) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
Domelight Super GRAY/VIOLET (+) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
LF Latch GREEN/VIOLET (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
RF Latch WHITE (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
LR Latch GREEN (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
RR Latch YELLOW (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
Trunk Trigger YELLOW/GREEN (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
Hood Trigger BLUE/ORANGE (OPEN) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
  THIS SWITCH RESTS AT (-) AND IS OPEN WHEN THE HOOD IS OPENED.
Parking Lights GRAY (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
Convenience
Headlights-Lo BROWN (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN
Headlights-Hi WHITE/ORANGE (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
LF Pk Lt Bulb VIOLET/WHITE (+) AT FRONT LEFT PARKING LIGHT
RF Pk Lt Bulb VIOLET/WHITE (+) AT FRONT RIGHT PARKING LIGHT
LR Pk Lt Bulb VIOLET/WHITE (+) AT REAR LEFT PARKING LIGHT
RR Pk Lt Bulb VIOLET/WHITE (+) AT REAR RIGHT PARKING LIGHT
All Hazrd Lights BROWN/YELLOW (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
LF Hazrd Bulb BLUE/GREEN (+) AT FRONT LEFT DIRECTIONAL LIGHT
RF Hazrd Bulb YELLOW/VIOLET (+) AT FRONT RIGHT DIRECTIONAL LIGHT
LR Hazrd Bulb GRAY/ORANGE (+) AT REAR LEFT DIRECTIONAL LIGHT
RR Hazrd Bulb GREEN/ORANGE (+) AT REAR RIGHT DIRECTIONAL LIGHT
Wipers-Lo GREEN/VIOLET (-) IN HARNESS AT VEHICLE WIPER SWITCH
Wipers-Hi VIOLET/ORANGE (-) IN HARNESS AT VEHICLE WIPER SWITCH
Parking Brake WHITE/VIOLET (-) AT SWITCH ABOVE PEDAL
Trnk Release BROWN/YELLOW (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
Seat Mem 1 VIOLET/WHITE (-) AT SEAT MODULE UNDER DRIVERS SEAT
Seat Mem 2 YELLOW (-) AT SEAT MODULE UNDER DRIVERS SEAT
Remote Start
Accessory 1 VIOLET/GREEN (+) IGNITION SWITCH HARNESS
Anti-Theft Type FORD PATS® OR SECURILOCK® VEHICLE IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense BLUE/GRAY (+) IGNITION SWITCH HARNESS
Neutral Safety GREEN (-) IN HARNESS AT REAR OF GAUGES
  SHOWS (-) IN PARK OR NEUTRAL.
Crankshaft Sensor GREEN/BROWN (AC) AT PCM MODULE AT CENTER OF FIREWALL UNDER HOOD
Camshaft Sensor BROWN/BLUE (-) AT PCM MODULE AT CENTER OF FIREWALL UNDER HOOD
Brake Lights VIOLET/WHITE (+) AT SWITCH ABOVE PEDAL
Reverse Lights GREEN/BROWN (+) IN HARNESS AT REARVIEW MIRROR OR IN DRIVERS SIDE A-PILLAR
Horn YELLOW/RED (+) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
Anti Theft RX VIOLET/GRAY (DATA) AT PATS RECEIVER NEAR IGNITION SWITCH
Anti Theft TX YELLOW/ORANGE (DATA) AT PATS RECEIVER NEAR IGNITION SWITCH
Rear Defrost WHITE/ORANGE (-) IN HARNESS AT REAR OF HVAC CONTROL PANEL
Heated Driver Seat WHITE/BLUE (-) AT HVAC MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH
Heated Passngr Seat GRAY/YELLOW (-) AT HVAC MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock YELLOW/VIOLET (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
PowerLock BLUE/GREEN (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
Driver Mtr Unlock BLUE/GREEN (REV) AT MOTOR IN DOOR
Driver Mtr Lock VIOLET/GREEN (REV) AT MOTOR IN DOOR
Pas Mtr Unlock VIOLET/GRAY (REV) AT MOTOR IN DOOR
Pas Mtr Lock VIOLET/GREEN (REV) AT MOTOR IN DOOR
LF Window Up BLUE/GRAY (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
LF Window Dn YELLOW/VIOLET (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
RF Window Up BROWN/YELLOW (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
RF Window Dn GREEN/ORANGE (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
LR Window Up BLUE/ORANGE (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
LR Window Dn YELLOW (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
RR Window Up GRAY/VIOLET (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
RR Window Dn BROWN/GREEN (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
Sunroof Open VIOLET/WHITE (-) AT SUNROOF MODULE IN ROOF
Sunroof Close VIOLET/BROWN (-) AT SUNROOF MODULE IN ROOF
Hawkeye thanks for posting that.  Z  :)
You don't have to share one. If you like I can take a look under my hood but there is an open mini fuse port with nothing on it that is Key On.
SHOdded said:
What is the load you are putting on that fuse (MAX) from the new device?
It's for my Snow Performance controller. Instructions say tap into 12v key on power... So I'm not sure on max amps...
ddlopes said:
What number fuse is it? And what's the name of that fuse tap your using ?
That's an "add a fuse" I have 2 15 amp fuses in it. If you look in your manual you will be able to locate the fuses around that open spot and tell what number it is.
