SHOnUup said:I have no idea on cost, I know when I replaced the hub assembly ' s on my trailblazer that the good ones were almost double the cost of the cheap assembly and was very easy to do.
SHOdded said:If you get it for free at the dealership, do it. Otherwise, consider getting the Timken heavy duty hubs instead.
Timken is a must, or OEM, anything else and you will be replacing in 15-20k.SHOdded said:If you get it for free at the dealership, do it. Otherwise, consider getting the Timken heavy duty hubs instead.
Really wouldn't want to suggest any kind of time frame as you never know.SHO-TYM said:SHOdded said:If you get it for free at the dealership, do it. Otherwise, consider getting the Timken heavy duty hubs instead.
How long can I drive on it if it just started making the noise?
What did that run you as far as cost goes?ZSHO said:The dealer performed the two front wheel hubs,bearings and the TSB washers,basically give or take 3hrs labor,need the proper tools if not take it to the dealer and not as a simple task as some might think.
Mine is a 2011 with 56k miles. Would it be covered under warranty?ZSHO said:Everything was covered under warranty,if thats not the case you figure 116.00 ea axle bearing and hub assembly from Tasca part # BT4Z-1104-B,heavy duty grease and 3hrs labor give or take a reasnable quote would be less than 600.00,hope this helps.
ZSHO said:Speak with your service advisor or stop by the dealer early in the morning and explain to them the symptoms your having,best of my knowledge that should be covered for 3yr or 60k coverage,they will most likely have to do some diagnostics first then go from there,try to do it asap,good luck.
SHOnUup said:2 bar, no blow off VAM , stock tune and then 15 minute battery disconnect and some add cruising time before going in. Think the CAI is ok?
I know.... we went camping in the mountains for the weekend, so there was some pretty spirited driving coming out of the mountains, and then to do a rapid lane shift and slam into a puddle at 45-50 mph after driving for 2 hours. I'm sure everything was really really hot, and then throwing cold rain water all over everything could cause some pretty nasty stuff.SHOnUup said:From no sound to that is pretty crazy for hub assembly. But the comment about the quick cooling from puddle really tingles my common sense bone the right way.
