lotusnotes
Hi folks! In need of a some knowledge here.. Recently picked up a 2015 Explorer Sport Ecoboost that was a bit of a mechanic special. Symptom was heavy smoking... and discovered that both turbo's were totally shot. Front one lost its turbine rear unit has huge play in it. Already Replaced front easily, and now moving onto the rear or "right" turbo as it's referred to. Where I'm at is I have it totally disconnected, however so far I can't actually REMOVE it from the vehicle.
I can maneuver it in it's little cavity that it's in, coming out the bottom it hits the front passenger axle/subframe, and trying to come out the top its hitting coolant lines, gets hung up trying to shove it back by the PTU / rear driveshaft.. the upper portion of the exhaust manifold, what the hell is going on? It seems like it should come out the bottom and it almost fits but not quite. I tried jacking the engine/trans up a little with a jack and block of wood on oil pan, and it almost clears, it really seems like it should come out the bottom, but due to the size and shape of it seems nomatter way I twist or reverse it gets hung up somewhere.
I saw this post which appears to be Taurus SHO and they hint that the lower subframe needs to drop which makes sense. I'd rather get it out without this but is any good ideas of how best to lower the subframe? Do I have to mark it for alignment before this, pull any steering components first.. ?
https://www.ecoboostperformanceforum.com/index.php?topic=9106.0
At least on the Flex forums these guys say it can be wiggled out by turning the long pipe of the turbo inboard but still not really sure what that means. I tried this last night and still couldn't get it out. Anyone do this on an Explorer Sport 3.5 ??
https://www.fordflex.net/forums/viewtopic.php?t=17751
Would really rather not remove more components or the subframe if I don't have to.. To anyone who's done this on an Explorer, how the hell did you get this unit out of here?
Thanks!
Thanks!
