Help set my expectations. Just did my SHO.. Not quite experiencing nirvana
I would definitely log it and retune ASAP.
I recently loaded my base 93 Torrie tune while waiting I'm waiting on some parts and there was substantial KR so I will just put up with stock for the time being.
TopherSho said:
Ok specs 1st
92p tune from Torrie
plugs (.028) from his site pregapped.
3 bar MAP
I programmed it last night, and have been driving for about 4 hours,  my impressions are 'good' but I am also thinking "this is not what I read the expected behavior to be".
Can the great internetz help set my expectations correctly ?
Without down pipes,  it feels remarkably the same under 2500 rpm.  AFTER 2500 it is 'stronger' but it is defiantly not ripping up my tires as some have posted.  I ASSUME that is expected since I cannot make boost that much sooner without HFC and downpipes.  please correct me if I am wrong on my assumption on this..
Another thing others posted frequently is the torque steer complaints.  Definitely not seeing torque steer issues either .. which make me think we need to data log and calibrate a bit (this is the 1st tune btw, no calibration has occurred yet).
The next thing that seems different than other people have noted is chirping tires.  Definitely not doing that.  It was a balmy 44 degrees F this morning and I gave it the WOT beans and certainly no chipping occurred on the 1-2 shift.  This btw is on some slightly cheaper goodyear DWS style tires.  Anyone else comment on 92p octane + 3bar + .28 plug performance up top?  It makes me wonder if I am reving too high (it wasin full auto mode) and shifting under powered.. (this has happened on the OEM tune where it runs right up to the limiter),  or if the AFR + winter gas is causing a loss...
Tq management.
Holy s***.  Its weird.  I am going to give it a week before I do anything but holy crap does it shift hard at 50% throttle. At WOT it shift likes bullet.  pop-pop-pop! not to hard, not soft like it was before but it snaps into gear quickly and without drama. *perfect*.
At normal speeds.. it is like normal... soft and grandpa lazy shifting.. slightly more throttle makes it crisper but the wife doesn't even feel the difference.
but at 50% throttle ... WTAF.  BAM!  Negans bat just hit the car in the ass. prime example I can replicate.. 50% throttle 4-2 downshifts are BRUTAL, LOUD and "did I break it" jarring.  Will that tone down over time?  Or do I need to adjust the pressure for downshifts?  In my head I really do not care about downshift pressure.. I am happy to soften that up.  All I care about is the much crisper upshifting under wot which 'seems' fine..
At 50% throttle upshifts are also pretty hard.  Not spine shattering, but it is eye opening at 5:30am. I have not made my mind up yet on the harder upshifts when not WoT... I am thinking when at the track WoT shifts will be more important to reduce ET's by reducing the time spent soft-shifting.  Dunno.
I fully expect the need to re-calibrate.. so I am not disappointed at all.  but i am curious if others have had similar experiences or advice.
thank you in advance.
I worked a lot with unleashed here is the deal you have to log and tell him what u want. The car in the learning stages will bang into gear a few times then smooth out after some miles. The down shifts are firm and does not really slip into gear. From what I have researched to make sure the trans lasts you can tell him to smooth them out for you. But the first tune you get is just a safe base tune for logging purposes. Then you send it to him and he will send you another revision.
Yea lack of octane what do you have available e85? Only need 1 gallon to 5 to get e20 blend going. My car knocked on the base tune he will turn it down to eliminate the knock.. added the mix turned it way all the way up 7 revisions. E85 is 1:70 a gallon here and only have access to 91  so for that I could turn up the car all the way up till it knocked or ran out of fuel.
