As metioned a while back,cleaning those map sensors is crucial for optimum performance,did you try swapping both the 3-bar sensors around and monitor for any changed reading,maybe a new 3-bar map is in store.ZShoBoat said:So a small update, I swapped out the plugs again and no change. I then proceeded to re clean the 2 map sensors and I reset the learned behaviour through Forscan. (Reset trans and other adaptations). Weird it's not as bad as it was. Even KR seems to be lower than before. It's still there but not nearly as severe. More to come.
ZSHO said:As metioned a while back,cleaning those map sensors is crucial for optimum performance,did you try swapping both the 3-bar sensors around and monitor for any changed reading,maybe a new 3-bar map is in store.ZShoBoat said:So a small update, I swapped out the plugs again and no change. I then proceeded to re clean the 2 map sensors and I reset the learned behaviour through Forscan. (Reset trans and other adaptations). Weird it's not as bad as it was. Even KR seems to be lower than before. It's still there but not nearly as severe. More to come.
May be a thing to consider not withstanding everything else... What brand of gas are you using... In AZ the octane rating can be as much as 2 points below posted signage.... Low octane will up your KR real quick with s performance tune.FoMoCoSHO said:Shoboat, if you dumped a tank of 87 on your stock tune, you would probably have a stroke due to the amount of +KR activity, LOL!
We sometimes like to experiment with our cars and get a true feel on how maybe the oil,fluids look and smell like,nothing better than getting familiar with your car and sometimes even dirty,its a thing called (manual labor)something to take into consideration when your warranty runs out.Zajpturbo said:Shoboat u may need medication for a busy mind lol...programming changes all the time during a run of the same body style nothing new there..that why there are many different strategies
Ur tune may just need a tweak due to something being slightly different than last season...or let the sensors do what they do and work for u....sounds like u are reaching for some wierd reason causing a slight quirk....maybe it's time for lms v9 tune lol
ShoBoat said:LOL ZSHO. I do like to work on my cars. I guess from my old days of being a mechanic. But I did a little more messing around last night, I tried the 93 base tune (no mods) and swapped the map sensors. Still had a misfire, however after resetting the adaptations is was gone. For a while at least. I wonder if the dealer when I was last in a few weeks ago did an update? I will get with LMS today and see what they say. Interesting that it was gone when I first reset the adaptations.
I guess the best thing to due is to check to see if your strategy code was changed with your tuner device.ShoBoat said:LOL ZSHO. I do like to work on my cars. I guess from my old days of being a mechanic. But I did a little more messing around last night, I tried the 93 base tune (no mods) and swapped the map sensors. Still had a misfire, however after resetting the adaptations is was gone. For a while at least. I wonder if the dealer when I was last in a few weeks ago did an update? I will get with LMS today and see what they say. Interesting that it was gone when I first reset the adaptations.
BiGMaC said:ShoBoat said:LOL ZSHO. I do like to work on my cars. I guess from my old days of being a mechanic. But I did a little more messing around last night, I tried the 93 base tune (no mods) and swapped the map sensors. Still had a misfire, however after resetting the adaptations is was gone. For a while at least. I wonder if the dealer when I was last in a few weeks ago did an update? I will get with LMS today and see what they say. Interesting that it was gone when I first reset the adaptations.
I'd definitely check on that... if you wrote down your original strategy code you can just ask the car for that code using the MyCal engineering mode... If the dealer updated it you'll have a new SW ID and a new strategy code.
I do know that the '13+ have forward and backward learning, so you can flash any tune... but it might act unusual.
ShoBoat said:BiGMaC said:ShoBoat said:LOL ZSHO. I do like to work on my cars. I guess from my old days of being a mechanic. But I did a little more messing around last night, I tried the 93 base tune (no mods) and swapped the map sensors. Still had a misfire, however after resetting the adaptations is was gone. For a while at least. I wonder if the dealer when I was last in a few weeks ago did an update? I will get with LMS today and see what they say. Interesting that it was gone when I first reset the adaptations.
Hey BiGMaC, you wouldn't happen to know how to enter the Engineering mode on the MyCal?
