Hesitation and high KR Cold weather issues?
SHOnUup said:
EGR system malfunction can cause random misfires across many cylinders right?
Rich
Not sure, maybe someone can chime in. I am not familiar with the EGR system on the SHO. Just a reminder that it has 0 misfires with the stock tune. I am not sure what impact the tune would have on the EGR system.
The misfires do not trigger a code. I guess it's under the threshold for the count. But it can be felt and it shows up for the current count on the PID for total misfires for the current drive cycle.
I think u all may be reaching if trying to contribute a misfire to an egr issue...most late model cars don't have an egr valve per say like the old cars...egr is done via cam timing through exhaust gas reversion
Just my .02
Just my .02
You could be correct, I am leaning towards a winter gas combined with a tune issue. I had 0 issues with the V1 tune. Which I drove on the car all winer long. When I put on the winter tires I put the car back to stock.
Could fuel providers be dumping the last bit of whatever winter blend is left into tanks regardless of octane rating? Wouldn't surprise me.
Rich
I'd really like to know what the problem is...I've thought about it a good bit and I really can come up with anything u haven't already tried
Thanks Guys, I know for a fact that the V7 tune had issues with winter gas. Hence the V7 CW tune revision. I was hoping there was another 13 SHO in Ontario running the V8 tune that could comment.
I don't know all the intricacies of the lms tunes but I remember reading something about them needing a cold weather tune.....could it be that the v8 tune needs tweaked and u have stumbled upon something because of your attention to detail?
Maybe others don't notice because like u said there is no dtc and if some others aren't logging misfires they wouldn't notice either?
It's possible, however you can feel it. Unless its less severe depending on your location. I have been reading up on winter gas mixes. And it is location dependant, for example my local mix would be different than say NY state. Apparently they add a lot more Butane around here. (it's also really cheap). I have one last ditch attempt. I am waiting on the local race gas station to open this up coming week. I am going to run a full tank of whatever the lowest grade he carries. I think its 98 or 100. If that fixes the issue then we will know what the problem is. Octane itself should not have an impact on misfires, I would think. The composition of the fuel I think would. Also the fact that it doesn't do it when its warmer weather also indicates that it might be tune related in combination with the fuel. The ECU changes the timing and boost according to the ambient temp. Just throwing some ideas out there.
I have really been trying to think on this one,if the misfires are random then it could be low fuel pressure,intead of her running fat and rich,she is running LEAN,BTW there is no V1 or especially V9 tune LOL  Z
there was a V1 tune lol, my 13 got the first version of the 13+ SHO LMS Tune. Back in April of 13. Also looking at the logs it's not running out of fuel. You can see one bank go slightly richer when the misfires occurs. Fuel pressure is also good both HP and LP are within range.
I guess the best thing to do is a IDS with power balance to see exactly what cylinders are missing,heres a little video to get an idea,and never knew that the V1 was ever released,recall when Rick from LME mentioned something about it but wasnt sure if it was official.Z    https://www.youtube.com/watch?v=jOFL99D_f4Q
Thanks for the Vid, there is something similar in Forscan that I am going to try.  I am also adding in a few other Pids and see where that gets me.
So after a few days of Data logging and a Forscan update, I believe that I have found out the issue. Rail pressure is dropping to below 1000 on the WOT runs. However the fuel to air ratios are within spec just below 11. It looks like the simplest solution is typically the correct one. The "winter gas" which on more research has less BTU energy than summer gas. The, butane and propane that are laced in the fuel in higher quantities mess with the AFR and the car thinks it's running lean and continues to dump more and more fuel to compensate. Add into the mix at least 10% Ethanol and you get the picture. Less BTU energy and lighter fuels and we have a situation that the car can't solve on it's own. This is the reason that on the stock tune the car has no issues whatsoever. With the V8 tune regardless of 91 or 93 map it runs like crap when it gets cooler outside. This is the reason that it went away for a few days, the ambient temp rose above 20C here during that time. Then on Saturday it dropped below 10C. Yesterday the high for the day was 8C. With the increased demand on the car the fuel system in combination with the LMS V8 tune was not up to the task. I sent my logs to LMS which I will post below. I have not had a response as of yet, I don't really expect anything to materialize. Their attitude towards data logging through the OBD2 port is well known. Even though Ford does use it to diagnose your car or truck through the same port. I had a similar issue last spring when I switched to the V7 tune, then the V7CW and finally to the V8 tune. I had my car at the dealer several times looking for an mechanical issue (none were found) with the car and then suddenly it went away all on it's own. This was in May. After it was warmer and the local stations switched from winter to summer gas formulations. I'm not sure if there is a difference with Canadian and American winter gas formulations, or if like me guys in colder climates revert to stock for the winter. This could be the reason not more issues have materialized. I still plan on trying out a 91 non Ethanol fuel and see what that does.
It seems that a few I told you so's might be in order so get it off your chests lol.
I forgot to mention the logs below were taken on the same day same conditions.
Could it be your HPFP?
Was that pump pressure or rail pressure?
I've seen lower pump pressure than that without misfires and the car held AFR as well.
I ran the gamut of E blends tuned and untuned and the car never behaved like yours.
I did run out of fuel twice this winter but due to bitter cold and me being a little overzealous with the corn :)
You may have more going on than that. I'm lucky to ever see over 1000 psi on the rail. It's no discovery that cold temps, and higher ethanol content will tax a fuel system. Nothing new there. I wouldn't contribute your drop in rail pressure primarily to the temps but more because of the high boost you are running.
I have my tune and trans so that when I'm in Select shift mode and I floor it the car won't downshift and it will hold whatever gear I want. You should see the rail pressure drop when you are at 20 psi and 2000 rpms. It's fallen to 600 psi. I get no misfires but AFR will start to lean.
I'd like to see you log ACTUAL THROTTLE position. I've ran my car 18-20 psi when it was 5 degrees Fahrenheit and it tolerated it. The fuel where I live is E10. It's the boost that taxes the fuel system the most. That's why the METH is awesome. It's extra fuel and gives the cooling since the air is heated so much from the high boost.
The warmer air may make it better for you but I don't know why you are getting the missing....I still have the stock plugs and have run very high boost at 5 degrees F. That's getting pretty cold..
If you have time or get around I'd love to see a WOT pull while logging actual throttle position.
OBD II logging through livelink with SCT is highly accurate and is displaying the readings from the actual OEM sensors that are relayed and interpreted by the ECU so if the car uses them they must be OK
FOMO you beat me lol my post was too long...I was thinking along your lines as well....The misfires are weird to me
Rail pressure, LP was over 100PSI both tunes. I don't believe that the car was actually running out of fuel. More like flooding itself. I read an article on how the different fuels, like propane, butane and ethanol mess with the O2 readings. For example. The car is reading 10.8 AFR, when in fact its more like 10 already. Tuners have to account for this when tuning for E85 or Methanol. The AFR reading in the car is calling for more fuel more fuel. And eventually it either runs out of gas or in my case misfires due to too much fuel. If you look at the AFR readings on the car during the runs you can actually see when the misfire occurs and one bank will go rich. Down 0.5 lower then the other side. The car never actually leans out. The car is flooding itself (kinda like an old school carb lol).
Below is some notes that I found on the different afr values for E85 for instance. Propane and Butane also effect the stoichiometric air-fuel ratio.
http://www.brighthubengineering.com/machine-design/15235-the-stoichiometric-air-fuel-ratio/
E85 has a stoichiometric fuel mixture of roughly 9.78-9.8:1 in E85's purest form (Class 1 85% Ethanol summer blend). As the fuel's Ethanol content goes up the stoich range goes down. For instance, 100% Ethanol's stoich is about 9.0:1.
E85 will maintain max brake torque much richer than stoich than gasoline will. But, because of it's excellent detonation threshold(due to lower combustion temps, lower peak cylinder pressures..etc), it can be run much closer to stoich than gasoline safer. E85 reaches max thermal efficiency at about 13% richer than stoich, whereas gasoline is about 16% richer than stoich(with pump gas being even richer). But again, E85 can maintain Max Brake Torque well into the 30% richer than stoich range, unlike gasoline which is limited to about 18% rich of stoich. DISCLAIMER: Just because E85 itself will still make power at super rich AFRs, doesn't mean it's a good idea or even recommened. A whole host of issues come with running super rich AFRs, that you need to be aware of, but i will cover later.
Therefore Max Rich Torque of E85 is 7.1:1- 8.5:1
"With that being said, here is what i would consider a very safe and conservative fuel tune on E85. *AFR's listed in bold are for widebands o2s that are calibrated for gasoline, AFR's in ( ) are actual E85 AFR:
Part Throttle lean (max eco) AFR of 16.5:1(11.0:1) 12.4% leaner than STOICH
Part Throttle rich AFR of 14.7:1(9.8:1)
Spool up... AFR of 13.5:1(9.00:1)
WOT... AFR of 12.1:1(8.06:1) 17.7% richer than STOICH
*If you're using a wideband that is calibrated for gasoline(14.7:1) and cannot change the calibration of the wideband, take your gasoline AFR and divide it by 1.5 to get actual e85 AFR or use the wideband in lambda mode. 1 lambda is 9.8:1
Here are some common AFR conversions(Gas AFR on left, e85 on right):
18.0:1=12.000
17.5:1=11.666
17.0:1=11.333
16.5:1=11.000
16.0:1=10.666
15.5:1=10.333
15.0:1=10.000
14.5:1=9.666
14.0:1=9.333
13.5:1=9.000
13.0:1=8.666
12.5:1=8.333
12.0:1=8.000
11.5:1=7.666
11.0:1=7.333"
