That's phenomenal! Don't know many places that offer that kind of customer service. LMS definitely just went up a few notches in my book.
polskifacet said:Not from the dyno, no. I do however still have massive hesitation when it downshifts during WOT. Concerned that they said it safe when there is no way this is healthy.
polskifacet said:Had an open piece of road to do some testing on. It seems like it struggles at lower RPM to meet fuel demand. If i floor it at a higher speed and its going through the gears, it is meeting desired HPFP, up shifted from 3rd to 4th and good fuel pressure through all of 4th.
StealBlueSho said:polskifacet said:Had an open piece of road to do some testing on. It seems like it struggles at lower RPM to meet fuel demand. If i floor it at a higher speed and its going through the gears, it is meeting desired HPFP, up shifted from 3rd to 4th and good fuel pressure through all of 4th.
We are getting to warmer weather now which helps with the fuel pressure issues... less dense air...
StealBlueSho said:I thought you said at lower rpms? I am confused... so I am guessing that a 0-60 pull is when you still have issues? Maybe I am misunderstanding?
From what I understand LMS put a fuel pressure gauge on it and ran it on the dyno, came out ok.ZSHO said:Did you ever check the LPFP ?.Z
Yes this is what they said.StealBlueSho said:And LMS said to not worry about the drop in FP and accompanying hesitation?
polskifacet said:Yes this is what they said.StealBlueSho said:And LMS said to not worry about the drop in FP and accompanying hesitation?
StealBlueSho said:polskifacet said:Yes this is what they said.StealBlueSho said:And LMS said to not worry about the drop in FP and accompanying hesitation?
That is phenomenal.... did you ever monitor your STFT when this hesitation occurred? I can mail you out my spare HPFP to test a different fuel pump if you want... I would like it back though.
StealBlueSho said:Hmmm... how low was your fuel rail pressure getting, do you remember? I have had mine drop to 800psi before and it hesitated/shuddered until the pressure came back up.
