Black Coyote
What's dtcSHOnUup said:Any dtc with it?Black Coyote said:Smh..what does service advance trac mean? Came on when I turned the advance traction control off..
THATS A B100 steering angle postion senor,lolSHOnUup said:Also saw something about "steering wheel position" sensor, but that thread died with no confirmation.
The washer is apart of the hub issue or something totally different?ZSHO said:Black Coyote's issue is his wheel hubs and tsb washers need to be replaced,also happened to me getting DTC CODE B-1OO,steering angle sensor at wot,after performed the hubs and washers there are no more codes,all related to the front end.
O ok I see.ZSHO said:The thrust washers are on the half shafts and usually the dealer would only replace the hubs,bearings.
5w30 full syn here MobilBlack Coyote said:What oil do you guys run in the SHO's ?
Awesome. Cheap place to get the oem filter?SHOnUup said:Not a drop. Went with OEM filter also. I have changed the oil twice now at 4k intervals.
Rich
Amsoil 0-30Black Coyote said:What oil do you guys run in the SHO's ?
