HID bulb issues
shweetpickens
Im having an issue with my 2013 Sho headlights.  At around 40k miles my drivers side bulb started turning itself off. I could turn the switch off and on to fix it but it would go off again after a minute or two. That along with the fact that it was a different color told me that it was a bulb problem.
I replaced both bulbs with morimotos D3S and the problem was solved. Now two months have passed and I noticed today that the same side bulb was off??? I flipped the bulbs off and on and they both worked again. Both bulbs still look the same color. I have factory ballasts, and the igniters I believe are part of the D3S bulb. What do you guys think this could be? Did I get a bad bulb??
Have seen it posted that moisture in the headlight assembly and/or water intrustion into the bulb connector has caused this type of problem.  So I would check the headlamps carefully for moisture, and clean and grease (dielectric) the bulb connector.  See if that helps any.  Also check the fuse for that headlamp.
Same thing was happening with mine.  Driver side bulb would just randomly just go off.  I'd turn the lights off and on and they'd be working again, but would eventually just turn off again.
Swapped out my bulbs for a pair of philips and they've been good since.
Other than swapping out the ballast, you may want to try out another pair, but different brand.  If you get a ballast, I'd get a new one and oem.  I believe osram is oem.
Thanks for all the ideas.  Ill check the connector.  Do you guys really think a lesser brand of bulb could have this problem after 2 months of use but a good brand would not?
Even Morimotos can have a bad bulb now & again.  The tops in lighting have usually been Philips and Osram (not Sylvania), and their prices reflect it.
Thanks just wanted to make sure I understood you right.  Thats probably my next step if this keeps up.  I know theretrofitsource.com is a good place for LEGIT bulbs.  Do you know any other good sites where there is no danger in buying a knock off?
pmezo33 said:
These are the philips bulbs i put in and i think they're a nice upgrade from the stock osrams.  They're brighter and i like the color better.  Definitely happy with the change.  Got them from hidconcept too.  Free shipping and a 15% off coupon.
http://www.hidconcept.com/d3s-philips-x-tremevision-42403xvc1-hid-50-bulbs/
Do you feel like they look any better than stock?  I know 4800 isn't a huge jump over oem, but one of the things I liked about my morimotos was the slightly more blue look of them
I do and it's definitely got a blue tint to it.  It's not obnoxiously blue (personal opinion) like some cars on the road, but they definitely have a slight blue tint to them.  Stocks don't have any blue tint.  If you really want to go blue, you'll have to go 6000k or more.  These are more white with a slight blue tint.  This is the ideal look i like with HID lights though, so i consider them a big upgrade over the stocks.
