HID headlamp upgrade EVOX-R
Would you mind updating the pics in this thread, ShoBoat?  Quite a few seem to be erroring out?  TIA.
This sucks: passenger light isn't lighting anymore. And as I am alone with my two young children sleeping in the house, I can't troobleshot right now. Anyway here's a pic with only one light.
And front shoot
How is it wired? Relay harness or direct? Funny (not really) I had one of my ballasts fry last night. It could just be a loose wire.
If it's a ballast (hope not) I have a pair of Morimoto 5five on hand. My retrofitter didn't want to use them because it would be too bright he says.
If it's a harness setup, chances are it's a loose wire. When mine went it blew the fuse and both were out. I had to pull both ballasts to find the issue. Unless both headlights have their own fuse. Or it could be a bad igniter. Seen that happen too. Good luck with the trouble shooting!
Per the 2013 US OM, 20A fuses 57 and 78 underhood are for the OEM HIDs.  Don't know if that is different on Canadian spec SHOs or not.
BigPelo said:
Morimoto kits have one fuse per bulb directly on the relayer harness. I would prefer a loose wire anyway.
Weird, I have the Morimoto kit and relay harness and I have only one fuse for the ballast power.
