I meant moving the knock sensor to another cylinder. I do not think that will really do much other than verify that the sensors are good and you have an issue with #6, but always nice to completely isolate the issue...mwemaxxowner said:What do you mean move that knock cyl to another cyl?
Yes, it can be tuned with knock per cylinder. But global knock is safer, because it pulls timing across the board. So the idea here was to begin with global timing, watch data as he makes changes, and when data looks safer switch to cylinder knock.
I'm logging knock per cylinder on the OEM calibration, and that's most of what I've discussed here.
I'm not entirely sure it's isolated to one cylinder. Sometimes when I hear my knock sounds all 6 cylinders drop to a negative KR.
The data looks much better with the tune I have than OEM. My main concern was for him to help me determine if it is a programming issue, a hard parts issue, or an electronic issue. Which is still to be determined. As far as I know it *should* run fine on the stock tune.
I only mentioned the bit about his tune to say he was able to force better afr numbers. So does that mean anything useful?
Sent from my Moto G (5) Plus using Tapatalk
I have no idea who is doing your tuning, and am not sure if all tuners can (or will) use per cylinder KR. I was just mentioning AJP as and option to consider as I am pretty sure he does and thought it might help in your case.
