High EGT Part Throttle
boostedflex
Hey all,
The last few failures has me a bit nervous, so I wanted to ask you all (and possibly Torrie) about something I have noticed for a while.  Under light throttle conditions, my EGT's climb to as high as 1450.  What is odd is it is only light throttle, full throttle it will drop considerably (1200 or less I believe).  Is that too high for light throttle conditions, should I be concerned?  I get 0 knock and AFR seems normal, just the high EGT under light driving.
Thanks,
Rik
Light throttle = running lean = hotter exhaust temps
Heavy throttle = running rich = lower exhaust temps
1450F is well within safe parameters.
As long the temp protections aren't disabled then I wouldn't worry about it...The car will tell you when it's not happy with a CEL or DTC
While it's true running lean can make EGT's hot but  when running rich and under load for an extended time that is when EGT's will be hottest.
Without looking and off the top of my head I believe the stock temp limters are around 1700-1800 as the starting temps to trigger CEL's and failsafe cooling and fuel control.
