Sounds nothing like this....
https://youtu.be/45woF4vZLU8
Colorado-SHOBro said:another thing i just thought of if you're feeling a vibration . . i can always feel an instant vibration the moment the fans kick on. it's very brief and once they get up to speed i don't feel it anymore but if you're right on the coolant temp where they're kicking on/off i would think you could feel that. .. which could explain the "shudder" but not the ping sound.
timing chain also came to mind for me. . have a mechanics stethoscope?
SHOdded said:Do you still have your stock downpipes? Try swapping out the SWs.
Also monitor transmission PIDs, see if it might be the torque converter. That rpm range is a bit wide, but could be a lockup issue. Note what trans temp is at the time the stutter/shudder goes away. See if the issue occurs at cruise in that rpm range also.
TopherSho said:Did you take the styrofoamy muffin off the fuel pumpy thing on the head ? mine sounds ALOT like that with it off ...
sholxgt said:TopherSho said:Did you take the styrofoamy muffin off the fuel pumpy thing on the head ? mine sounds ALOT like that with it off ...
I did and agree about the sound.
StealBlueSho said:sholxgt said:TopherSho said:Did you take the styrofoamy muffin off the fuel pumpy thing on the head ? mine sounds ALOT like that with it off ...
Pretty much what my mechanic said..
sholxgt said:So that you know...that is the high pressure fuel pump. It's a mechanical pump driven off of the camshaft that bumps pressure to over 1,000 psi. Mine sounds exactly the same.
I have a Lincoln, so I can't hear the pump with the cover removed if the hood is closed.My extra 200+ lbs are mostly in insulation I suspect. Hood is composite, but NOT light either.
StealBlueSho said:sholxgt said:So that you know...that is the high pressure fuel pump. It's a mechanical pump driven off of the camshaft that bumps pressure to over 1,000 psi. Mine sounds exactly the same.
Yup, 100% familiar with it! I have replaced mine in the past during a fueling issue. I am familiar with that, the noise I am hearing is coming from behind bank 1 towards the middle of the engine. My mechanic said he didn't hear anything outside of the ordinary.
At this point unless there is something that happens, I don't think I have an issue... yet...
sholxgt said:StealBlueSho said:sholxgt said:So that you know...that is the high pressure fuel pump. It's a mechanical pump driven off of the camshaft that bumps pressure to over 1,000 psi. Mine sounds exactly the same.
Sorry, I should have quoted Topher. I know you're a pro with the fuel system in these cars. Probably one of a handful of people who have replaced the high pressure pump themselves.
Out of curiosity, when was your last oil change and what weight are you running? I seem to notice more valvetrain noise as my oil gets older. Granted, my lab results also showed my oil at 6,000 miles was pretty well shot.
I noticed this also. I took a video with it both on and off and there was a noticeable difference.TopherSho said:Did you take the styrofoamy muffin off the fuel pumpy thing on the head ? mine sounds ALOT like that with it off ...
