How to drain your CAC (Intercooler) with out taking it out.
If you have an air compresser and a blow gun nozzle. You get a piece of tubing like the 3/8 hoses used for catch can.  Make a small notch that the blow gun will fit.  And you blow away from the car towards your empty jug. It will work too.  Used to do this to empty radiator to swap t. Stats or change upper hopes..
You all know what sets this forum apart from the hate one, you guys all seem to put your minds together and come up with great ideas like this, and alternate/better mount locations, etc.  Really like to interact where there are other brains working and seeing things I may not be thinking of.  Hats off to all!!!
Oh, we still desperately need a F150 EB for the new CNC throttle body testing for mid next week now.  (were in West cent FL gulf beaches area). Owner gets free dyno sessions and a FREE first release CNC pattern port throttle body, and initial testing of the prototypes showed great gains.
Email us at: RXProducts@aol.com  if you can.
Thanks!
Tracy
I just check my intercooler and there isn't a single drop of fluid in it. I'll post the video in a min.
Sent using smoke signals.
What is your normal driving day like, wasinger?  Feathering the pedal, stop-n-go, lots of boost time?  Only a drop of waste here & there, for sure!
Would like to have Nighthawk do his IC also, he's got a hi-mileage SHO.
I only drive the car on the weekends which most likely allows the moisture to evaporate. But I expected an oily sludge if anything.
My driving habits are mixed. Some weeks I'll be doing lots of WOT data logs back to back and some weekends I'll just cruise around.
I poked the camera around the intake valves and they are dirty. More than I'd like them to be. I'll upload that video tonight. Maybe you guys can tell me if the build up is excessive.
Meth kit is next on the mod list for sure. Just wish I could use the max mpg snow kit.
Interesting, I wonder how much if any this buildup in the CAC is location dependant?
Here is the humidity average where I live. So it can be compared to others.
The relative humidity typically ranges from 37% (comfortable) to 88% (very humid) over the course of the year, rarely dropping below 18% (dry) and reaching as high as 100% (very humid).
The air is driest around July 8, at which time the relative humidity drops below 44% (comfortable) three days out of four; it is most humid around May 28, exceeding 82% (humid) three days out of four.
Just checked mine (I'm at 70k) and there is a good amount in there, about as much is shown on my dip stick as the first post. I tried to such as much out as possible but I couldn't seem to get much more than maybe a teaspoon. If I stick my dipstick down there, it still shows more. I'll be taking the front bumper off soon to remove the grille, and when I do I'll take a look at maybe putting a valve in the bottom of the CAC to be able to drain it easier. I will also be looking into getting an oil separator, thinking about a JLT for now.
Rich mentioned that you could jack up the front driver side so the crud flows over to the passenger side.  Should be able to drain out significantly more that way.
I had mine performed at the dealer with a compressor suction gun which pretty much sucked it up but the ocd in me purchased a 3' drain opener and securly attached a microfiber cloth to it,probably help with anything left behind.Z
Bringing this thread back! Just checked mine and there's close to a 1/4" on the dipstick. More than i'd like to see for sure.
^ Wondering if anyone has done a drainplug/petcock in the CAC? How difficult do you guys think that would be? Obviously it would have to have a good seal but the idea of just opening a valve and sucking the fluid out the bottom every 10k or so is pretty appealing.
Also,don't see why a cheap tool like this wouldn't work to drain it from the top. Just drop the hose into the CAC opening and spray away
http://www.homedepot.com/p/Husky-Siphon-Spray-Blow-Gun-9045734/203153526?cm_mmc=SEM%7cTHD%7cG%7c0%7cG-PLA-BT3-Husky-D25T-Tools%7c&gclid=Cj0KEQjw9b6-BRCq7YP34tvW_uUBEiQAkK3svUhx_wuJt0UbVJRj_ZDCuO0XU8ajK-iKEyCMnMzqRRAaAp-z8P8HAQ&gclsrc=aw.ds
The CAC is NOT an oil catch can that comes with a drain valve and would advise to Only Use a suction type compressor air gun on TOP to suck out any trapped oil inside the CAC as seen on my video and definitely a great idea on Top.  Z
https://youtu.be/urMO7Z5d02k
ZSHO said:
The CAC is NOT an oil catch can that comes with a drain valve and would advise to Only Use a suction type compressor air gun on TOP to suck out any trapped oil inside the CAC as seen on my video and definitely a great idea  on Top.  Z  [url=http://www.youtube.com/watch?v=urMO7Z5d02k#]! No longer available]! No longer available
Well obviously being a catch can is not it's purpose! lol. but what would be the harm in installing a drain valve in the bottom to easily remove oil buildup when needed?
