AJP turbo said:I just popped the cover when I changed mine. Just have to buy some RTV and you can wipe out more old fluid with a towel.
cseverens said:AJP turbo said:I just popped the cover when I changed mine. Just have to buy some RTV and you can wipe out more old fluid with a towel.
no issues with this? I want to have mine replaced soon, and the ford workshop manual says if the rdu cover is stamped steel (basically non ecoboost rdu), you can pop it off to drain and silicone it back up. it states that if the cover is aluminum (ecoboost) replace the rdu, it's not serviceable (even though there is a plug in the cover...). I would rather have the mechanic remove the cover and get all the crappy 80w90 out and replace with my 75w90 amsoil.
AJP turbo said:cseverens said:AJP turbo said:I just popped the cover when I changed mine. Just have to buy some RTV and you can wipe out more old fluid with a towel.
DOn't overthink it...No issues....It's just like any other rear end and there was shavings on the magnet ...I changed my fluid with less than 2k on the car to put real synthetic gear lube in. It's absolutely serviceable...I don't remember if the clutches in the electronic portion of the RDU are exposed to fluid or not but for me it's worth the 15$ qt of amsoil and a tube of RTV to have the best stuff in there.
metroplex said:I didn't know Ford claimed the rear diff fluid was lifetime, but my experience has been that the fluid in the back lasts a long time, like 100k+ miles. Maybe change it at high mileage (100k miles or so) if you feel the need.
Keep us posted, I am close to oil change time and while she is up in the air showing her naughty bits I might as well give her a thorough vaccination panel... I did PTU at last oil change, RDU now, and then synch them up in next series.FoMoCoSHO said:I went with Amsoil all the way around this time so I can see if the effect is the same (Amsoil is about half the price of QB fluids) but if not I will drain out the Amsoil and replace with QB.
