HPTuners
I am very glad to see LMS admit that the platform is out if fuel, I've been arguing this point for years now with various members.
Sent from my SCH-I545 using Tapatalk
Interesting...  Torrie told me all along that you would want to run Meth with 3bar to be safe.  The lower thermostat does not do much.  Due to the delays and all the speculation I'm not surprised of this outcome.  Did LMS ever straighten out the guy with 11k smoking turbo's??
Maybe, LMS ought to officially make a post about the new "XV1 update" instead of just throwing it into a thread?  I watched lots of mental masterbation about this for 4 months...
Well the
Livernois Motorsports said:
Unfortunately as to the release of XV1, it is going to require more ancillaries than originally thought. With the unique issues that have come to light with the cold weather, it has shown that we are at the limit of safe fuel delivery with our performance tunes already. Because of this, Xv1 will require methanol injection to utilize. We are working on other avenues for this to be able to be achieved without the use of methanol, but those are a long way off unfortunately. I understand the want and the frustration for the delay, but we would rather release XV-1 after its been complete and safe. One thing I am proud to say about our company is we will not just rush a tune out to the public without going over it with a fine tooth comb and test and retest to make sure it gets the most power out of the vehicle, yet still be 100% safe! It will require meth for the Explorer Sport, and the Taurus SHO and related vehicles (Flex, MKS, MKT). As for the F150, it is still in development, but as stated before, is only going to be released when perfect. I know it is frustrating, but please be patient. We just want to get everyone the best tune available, anything less would be a disservice to our customers.
Brandon
Thanks for the update. Then that settles it, I am maxed out on my tune, since I will not install meth. Glad I did not pre-order any parts.
Yeah, I'm not gonna do Meth either.  That's okay.  I'm good.  I'll be in the 12's as soon as I can get out there this Spring.  Still might want to do DP's and third cat delete sometime.
You can do downpipes, intake and exhaust and tune in stock fuel. If you don't want to run meth I have a solution for fuel using stock injectors and di pump.
We were actually the first to say this 4 years ago, but we are always looking for new ways to improve on our offerings. We are working on other improvements to be able to do Xv1 without methanol, but it will be some ways off before it can be done. But I can assure you, we will be the first ones with a proper fueling solution for these cars.
That car in question was picked up and brought to our facility for that, and further upgrades with the car. I definitely do not agree on the thermostat not doing much, but everyone is entitled to their opinion. Maybe if you are cooling the car down between rounds it doesn't do anything, but it has a profound impact on heat soak. As for delays, I would gladly delay something to make certain of it than anything else. How many tuners just push an update out after one or two cars and a few dyno pulls? Far too many unfortunately.
LMS has put a lot of effort into the EB platform, no doubt.  BUT, I think 4DR Mike has also done a tremendous amount on his own to advance the platform, including an aux fuel setup.  Got it to the point where the transmission needs to be addressed next.  Just saying.
There was a thread a while back about DeatschWerks coming out with larger injectors and a high flow fuel pump for the 3.5EB  .
Here is a link with further info : http://www.stangtv.com/features/sema-coverage/sema-2013-deatschwerks-in-line-fuel-pump-and-gdi-inhjectors/
Has anyone heard of any updated about this ?
I would rather go this route than have to deal with Methanol .
The solution for fuel that I have tested at E48 (50% E85/50% E10 91 octane) is the dual in tank fuel pump solution I have available with a fuel pressure regulator feeding the stock DI pump and injectors. The car worked great with this solution.
I can source all of the parts for you guys if you wish, right now you'll have to tap into the factory harness to feed the relays and use the factory fuel line as a return line.
I'm waiting for a returnless solution that would bolt in place easily, just waiting for Squash to finish their Uber Fueler. :)
That's 575 on pump gas for  you guys doing the math, easy, peasy.
Solution under $1000 and will easily provide enough fuel to do what you want without meth.
So kudos to LMS but I have a solution already that has been tested in depth on my vehicle with big turbos.
In the platform of the LNF engines, the platform is largely out of fuel immediately upon switching to E85.
Most guys run a larger cam lobe on the HPFP and recently have found some Opel DI injectors that flow about 15% more
On one of our team's cars we added port fueling in addition to a maxed out DI system and have broken the 600whp threshhold
This is full E85 car with PTE6262
That what I did to get to 600HP on E85 unfortunately the ECU is closed loop during WOT and when it recognizes the additional fuel it pulls fuel via STFT to attempt to hit commanded AFR. Not horrible BUT after awhile LTFT starts compensating for the additional fuel and then you start going lean again. I had a simple controller for the aux injectors that just looked at boost vs RPM and you put in values for the miliseconds of injector DC you wanted. I had purchased a microsquirt and was going to install an additional MAP and 2 WBO2 because that ECU would allow me to do commanded AFR as well and would have hopefully worked better with the stock ECU as it can auto adjust/tune to your fuel requirements, it also does fuel tuning on the fly instead of having to upload a tune with the car off (aux fuel controller). The transmission started going out on me before I could install and test however.
The result of my piggyback in my testing was that you'd be DEAD ON for fuel for 2 -7 days and then all of a sudden it would start hitting lean but, especially at mid rpm wot bursts and then I'd look at the logs and see it pulling more fuel than before, I'd at fuel it would take fuel away. After a few times of that I went back to my original aux injector controller settings and would then just start clearing the stock ECM by removing the negative on the battery for 10 minutes or so. Then it would work great for 2-7 days. :)
Would be so nice if we did not have to hack into the factory harness for the duel in tank solution. Is that possible 4DR?
On my LSJ i run a Deatchwerks dw300 in tank to a surge tank then to a bosch 044 in line.
Much better now and no more fuel pick up issues
Japeatr said:
I am very familar with HPtuners, as it is what i use to tune the Cobalts and a number of GMs.
The HPTforum i frequent is saying support will be coming soon, but no ETA. going to be stock until it comes out i guess.
Ecoboost is my top priority and we are actively working on it.  It will be released into the beta software shortly.
I think this will be a MAJOR step forward ...... subscribed !
Thank you for joining our forum and please keep us updated.. Love your software and its great results i have had in other platforms.
Thanks.  We currently have support for all of the non-ecoboost gas vehicles that Ford currently makes.  We are definitely playing catch up on getting the support for these added, but it is moving along quickly.
