ddlopes said:I ran a rev 10 tune that I got yesterday and didn't see any knock but Brad took timing out. So I'm not sure what my command for spark is. But I'm pretty sure it's on the low end. SBS where are you at with spark if you don't mind me asking.
ddlopes said:So we finally found the culprit of the knock with Brad's help and patients. After going through several different scenarios of what could be causing me to have knock even though I'm running 100% meth it turned out to be bad meth. Brad also did his magic messing with the fuel in the tune as well. I'm seeing approximately 50 degrees of temperature drop according to the IAT sensor. And I'm finally seeing cooling in first gear as well. Before I wasn't see cooling to later in the gears. I would like to say thanks to everyone for helping me. And especially Brad for everything he's done get this car to pull like never before!!!
ZSHO said:That's some Great news and hopefully you can start enjoying your SHO.
@ Trophersho did notice that your Methanol pale was somewhat different!!!
I think we need to start checking the validation and authenticity of any such Methanol.
Here's mine and pretty Fresh indeed with expiration date and all. Z
ddlopes said:The place get my meth now pumps it from 55 gallon drums. I store it in the VP plastic jug in my garage. Perhaps I should use a metal can to store it in now. The plastic jug may introduce moisture after sitting for a while (2 months)...
