tgambob said:Maybe change ramp of it or lift?
I think that is what puts more pressure on the cam
Here's a drunken idea....AJP turbo said:How would you run the pump?
The pump doesn't even run at 3K, it's capped at 2150 so there is some room if someone were to figure out the tuning.panther427 said:I always wondered how well a cp3, cp4 or other diesel injection pump would survive with gasoline. Obviously there is a huge difference in pressure. 3000psi versus almost 30000psi. But there has to be a way
Sounds like pump pressure, not rail pressure.tgambob said:I noticed the cap now that I'm watching fuel rail pressure through forscan. Idles at around 238 and max has been 2000 so far
FoMoCoSHO said:Sorry, there is a commanded pump pressure and rear (rail) pressure.
