D
Guest
You may have pre detonation at high rpms and not even know it without logging. OTOH, I was running stock 528's gapped at 35 for months with no problems. I'm pretty sure you are fine.
same here 528s gapped at .035 no problems, FWIW just purchased a set of 534s to find them already pre-gapped at the recommended .030 word must have gotten back to Momma Ford.DJE624 said:You may have pre detonation at high rpms and not even know it without logging. OTOH, I was running stock 528's gapped at 35 for months with no problems. I'm pretty sure you are fine.
Brucelinc said:One question: I have heard a couple of guys use the term "predetonation." I am familiar with pre-ignition and detonation - both are bad. Predetonation is a new one on me...is that just a made-up word or is it some evil combination of detonation and pre-ignition?
Tomc612 said:Yes they are Great!! Livernois stage 4+ I run and will never go back to stock. I also have a few files I use sometimes from Tuning by James. I been tuned over 22k and I never had any problems. I'm using the SP-534 plugs gapped@.030 for 3000 miles. I was running the older plugs with gaps as high as .036/38 and still never any issues.
Brucelinc said:Thanks, BiGMaC. I do not want to hijack this thread around terminology, but your description sounds like what I have always thought of as pre-ignition - the ignition of the fuel/air mixture occurring too soon and slamming into the piston on it's way up. This is often due to overly advanced timing and/or plugs in too hot a heat range. Anyway, regardless of terminology, we know it is bad and, thankfully, the best tuners help us avoid it!![]()
68_GT said:I don't like that the LMS XV1 tune has been put off either for a long time, or possibly forever with out meth. I'd buy support mods if needed to run it. I just want to run boost to redline my SHO leaves me wanting on the highway after 5k rpms. Maybe that will change with the release of larger direct injection fuel injectors possibly this year and some other fuel deliver modifications. Seems like there's just not enough demand for our cars to justify the additional time to work on our tuning.
DJE624 said:68_GT said:I don't like that the LMS XV1 tune has been put off either for a long time, or possibly forever with out meth. I'd buy support mods if needed to run it. I just want to run boost to redline my SHO leaves me wanting on the highway after 5k rpms. Maybe that will change with the release of larger direct injection fuel injectors possibly this year and some other fuel deliver modifications. Seems like there's just not enough demand for our cars to justify the additional time to work on our tuning.
You may want to check on a 3 bar tune. That's next in store for me. I thought that the latest tunes for 13-14's were equivalent to the Stage 4+. 4+ will hold the boost out longer. Our turbos are controlled by torque demand. If you are boosting over 14.5 the ECU can't read it and holds steady. With a 3 Bar sensor, your ECU can read boosts above 14.5 and supply more fuel. That may get you where you want to go.
SRT82ECOBOOST said:I could be absolutely wrong on this, but it was my understanding that the 3 bar really does nothing for you as we do not push high enough boost levels without meth to supplement fuel delivery. If I am wrong and I am leaving something on the table for performance, I will order the 3 bar immediately.
SHOdded said:If you are looking to increase boost using the 3bar, make sure you keep an eye on all those pipes & clamps if they are stock!
