I was running a 4x tune so I might have been near a 3.9-4.2 sec just didn't know if it was even remotely possible.Usmcsho said:So I have three bar, plugs, livernois tune and cai. I am running nitto INVO tires on a 22 inch rim 245 f 295 r. Using torque pro 0-60 app thing in a private road with no traffic I ran a 0-60 of 3.9 is that possible
Sent from my XT1650 using Tapatalk
is your speedometer corrected for the 22" wheel setup? does the torque pro app use gps info or obd info to time the 0-60? obviously if your speedo isn't corrected for the tire diameter that time is off.Usmcsho said:So I have three bar, plugs, livernois tune and cai. I am running nitto INVO tires on a 22 inch rim 245 f 295 r. Using torque pro 0-60 app thing in a private road with no traffic I ran a 0-60 of 3.9 is that possible
Can you clarify what you mean by this? Your log should have been showing you PID info, but you are saying that your log and PID differed?Gjkrisa said:Did you do multiple runs? I feel most of the time my 0-60 is accurate but I was looking at a log and showed I was going 90 untill I looked at vehicles speed pid and found I was only doing 50 with the afr to collaborate with that.
he's lms tuned. probably doesn't have anything to log withf8tlSHO said:Most accurate way to check 0-60 is by logging... I used an app on my phone, said 3.9.. my fastest run at the track was logged. It was a low 1.8 60ft but was 0-60 in 4.5.. car ran a 12.4 @ 111mph
That sucks.... canned tune... not for meColorado-SHOBro said:he's lms tuned. probably doesn't have anything to log withf8tlSHO said:Most accurate way to check 0-60 is by logging... I used an app on my phone, said 3.9.. my fastest run at the track was logged. It was a low 1.8 60ft but was 0-60 in 4.5.. car ran a 12.4 @ 111mph
Holy crap okay great to knowShoBoat said:3.9 is possible, I have done it at the track. So have others.
dubcitySHO said:Usmcsho, throw a pic of your car with the wheels on!
paokara777 said:3.9 with just a tune?
I find that difficult to believe.
Slips to prove what? Track times? I've never seen a track supply 0-60 times. What did your car run at the track?ShoBoat said:paokara777 said:3.9 with just a tune?
Dunno. Decent launch at the track maybe... mine does have DP, cat back, intake, stat and Tune I have the slips to prove it.
SHOdded said:Brucelinc's mks did 3.9s all day, based on the Aeroforce gauge.
