K&N filter, drop in or whole set up?
If we line up 2 cars for comparison, first we have to verify they are identical in every known respect.  The lanes should be identical in every known respect.  Then dyno/dragrace them.  Then compare changes one by one.  Has anyone established where the cutoff is for time differences to reach a level of significance?  Is 0.01 significant, or is 0.05 significant, etc.  Having a 0.1 second difference is probably a no-brainer :D
A statistician.... But a good point... When is P< .001  (the level of significance in medical stuff)?
(For you non-statisticians this means that what was reported has < 1 chance out of 1000 of being coincidence)
BiGMaC said:
navbtcret said:
I ran against a friend of mine this past Friday at the track, both 2013's and identical mods except he has a CAI and I have a drop in K&N. Every time we lined up against each other he was .01-.03 faster than me. He also has the Flower wheels and mine came with the 19's so that is a small difference too. Same cool down time and everything, so that make me think the CAI does add a little to you car.
A different finding than most have reported.... warrants a bit of analysis I think.
Do you have the timeslips you could post?  Interesting to see them I think.  The main variable not controlled is primarily the driver if both cars are either PP or non-PP.  I wonder if the drop-in is the problem....
Other member tests were same driver, same car, different runs (back-to-back) with AM CAI vs completely stock intake... 4DR and bamsho found stock faster in their trial conducted this way.
Removing the entire filter box (saxophone only open intake) vs stock showed no difference on the dyno in my '13 SHO nonPP... but of course that's not "real world"
They are both non pp, he has over 35k on his car and mine is just under 9k. Identical mods with the exception of the cai, tunes are both Livernois 3 bar v8 tunes. We swapped lanes as well with the same results. I will post up slips later, busy right now at work and slips are at home. He has the 20" flower rims and I have the 19" stock rims, 2013's both and he has the adaptive cruise but I do not. Those are the only differences in the cars.
We were both in sport mode with traction control off.
It would be interesting to see a dyno of the stock airbox but no filter. I found other tests that show the airbox and snorkle work together for proper flow. I like Big macs idea of testing without an airbox, but that will mess up the pressure/flow of the Intake vs just removing the filter.
