Keypad on the car
Exactly, Vernonator.  The system has sensors that know if the key is outside the car or inside.  Many people leave their fobs in their cars and use the same method that you do.  Unless someone else has access to your code or a Big Freaking Hammer, they will not get in.  Even if they break in, I don't think the car will start.
When I first got my SHO, I was having trouble being consistent with the two finger key press to lock. A suggestion from helpful forum member who shared his secret which is to use a thumb press between the two bottom numbers. Like magic that trick has worked for me very well.
I have at times not been able to get the lock to engage, When that happens,  I have found that all I have to do is an unlock swipe to reset things then follow with the magic thumb press. BTW key fob in the pocket!
yowen said:
I was washing my car yesterday and noticed that if I spray the keypad, the numbers light up, is this normal? Or do I possibly have a short or some other problem in there?
Normal. The ESport does it, and my wife's old Edge did it as well. I'm assuming the fob is in your pocket when this is happening....
I evidently misunderstood this and thought that if the fob was in the car, just touching the keypad would allow entry. Thank you for clarifying on this feature!
What's the procedure for unlocking when you've left the fob in the car and it's battery has gone south along with the fact that you are nowhere's near your spare fob? BFH?
That depends, is your car battery dead too? Do you know your entry code? At that point you'd be looking at lockout service and a battery boost, haha.
Car battery dead… it would have to REALLY be dead… can't find that in the manual.  All other situations ---> Enter your code (or the factory code which will always work)… :-[ The keypad doesn't require the fob present in order to function…. you can also do some other pretty neat things id you want… one door, all doors, trunk, etc., and up to 2 different drivers can have their own separate codes.
Here's the 3 pages from the manual (click images to enlarge)
Go for it!  :beer2:
If the battery in the fob is dead and the battery in car is dead and my cell phone is dead, I would use the BFH to beat myself on my head.
Seriously, the keypad operates from the car battery and use of the fob operates from the fob battery.  You can still start the car with a dead fob by putting it in the appropriate slot so assuming the car battery is not dead, you could drive to Walgreens or Batteries Plus and buy a new fob battery.  :hitit2:
Hmmm  :hmmm:  I seem to remember that I couldn't lock the car when the fob was in the car, it kept unlocking..but maybe it was because the car was still running...I know that with My F-150 you could lock the doors with the engine running...don't ask why I know this because it's a long story and makes me look really stupid! :wall:
You can't just press the lock button on the inside door.  If you do and then close the door it will unlock and beep at you.  You MUST lock it with the keypad if you leave the fob in the car.
Where is the spot to put it should the fob be dead?
Below is from the MKS manual.  Pretty sure the SHO is the same.  There should be a slot in the glove compartment.
Backup Method of Starting: Your
IA key uses a radio frequency signal
to communicate with your vehicle
and authorize your vehicle to start
when you press the START/STOP
button and apply the brake pedal. If
excessive radio frequency
interference is present in the area,
or if the battery in your IA key is
low, it may be necessary to start
your car by inserting the IA key in
the backup slot, located in your glove box. Insert the IA key into the slot
with buttons facing out and with key ring up.
For my SHO, the location to place the dead FOB is inside the center console and not in the glove compartment like the MKS. It is in the rear driver side corner I believe.  It should follow the same orientation rules as in the MKS manual above though.
