Scott13SHO
Member
I finally got around to switching around the settings on my Interceptor gauges to display if the ECU is pulling any timing from the engine. I did my 15 mile ride into work today and I saw that the engine was pulling timing in low load applications at times (like low RPMs going over a hill or only using 25% throtal) but not when I floored it...I'm assuming this is fine since detontation more dangerous to an engine at higher RPM's and I've experanced knock on NA engines when "lugging it" at lower RPMs from "spark knock"?
I have a Livernous tune and an intake on the car...so discuss...
