explorergotoluvit
Can anything with one launch pass 2 hundred rpm with out it stalling out?
explorergotoluvit said:Can anything with one launch pass 2 hundred rpm with out it stalling out?
kinda sounds like this could be happeningpanther427 said:When I try to launch over 2500 my car will open the bov and dump all the air out of the system.
Didn't know thatSHOdded said:Remember that optimum rpm drops with a tune in place. Stock, 2500 rpm launches are a possibility; tuned, 2000 rpm launches are highly recommended. That's just the way the torque curves play out, at least on the SHO.
yes around 2K RPM launch are pretty damn good I agreebigmoneycloser said:I have done a few launches braking up to 2k rpm then gooooo... Only with TC off. With no issues.
I didn't notice any rpm limits either, but I was trying to stay at or under 2k...
The TC will shut you down if it don't like what your doing...
Josephm said:It goes into protection and cuts all power. Its because your front tires are spinning faster than the rears. Mine has done it a few times at the track
Courier6 said:I played around with RPM on launches a lot at the strip, best times were achieved around 2K RPM, that was the sweet spot on my 2011 and 2013 SHO's.
