Agentlongwood
Alrighty, so I never liked the way catch cans are configured for our cars. They seemed oddly complex, with the T-junctions and what not. So I put some thought into it and connected a system in a way that I think is better. Coming to you guys to tell me if I've done something catastrophic by mistake, lol. So this setup does not need a clean side separator, and it allows you to keep the original oil cap in place. All the lines are 1/2inch fuel hose, squeezed onto the Ford factory plastic connectors. It uses no T-fittings, and 2 check valves. The check valves are not in the usual place though. I took some pics and labeled the lines to walk you through what I've done.
Line A: Vapors come out of the dirty side and into the center fitting on the catch can. No need for a check since the PCV unit itself only allows vapors to come out, not in.
Line B: The first vacuum source at the intake manifold, connected to the rightmost fitting on the catch can. Check valve installed so that when the motor gets under boost it isn't sending boost into the can.
Line C: Second vacuum source. Connected from the leftmost fitting on the catch can, to the front BOV re-circulation point. No need for a check valve since this is before the turbo. Therefore it is never pressurized, and always under vacuum (though the amount of vacuum changes). At idle it is a teeny but of vacuum, and under boost it provides more vacuum.
Clean side intake: The clean side is where I made the biggest change from the usual setup. I wanted a source of fresh air for the crank case, without drilling the intake or buying a clean-side separator, or any of that stuff. So I put an air filter on the factory clean side connection. But since I wanted it to ONLY allow clean air into the crank case, and not burp oil out, I put the filter at the end of a short section of hose with a check valve in the middle. There fore nothing comes out of that line, only fresh air in.
So it goes like this. Fresh air is sucked into the clean side without anything being allowed to flow back out. It comes out the dirty via Line A and into the can. Vacuum supplied by lines B and C at idle, and when under boost by Line C only. But how do you drain the can? Well I'm glad you asked. I ran a line from the drain on the bottom of the can, down next to the washer reservoir, and installed a valve at the end under the car. You can't really see the line from the engine bay, but here is where I put the drain valve.
From that angle, it looks like it hangs really low, but it isn't actually that far. If you look at it dead on from the side it's maybe 1 inch lower than the lip.
Here are a couple more reference photos
I checked all the connections by to make sure air only flows the direction I want it to. And yes... I checked by putting my mouth on the hoses and blowing out and in. Everything flows correctly and you cannot blow the "wrong" direction in any of the lines.
So what do yall think? Any reason why this setup wouldn't work? I think I covered all my bases in regards to connections and flow direction... but I'm new at this so any feedback is appreciated. If I did screw something up, I'm gunna be real mad because this setup cost me a trip to the urgent care. I cut my left index finger REEAAALLL bad with some garden shears when I was trimming the fuel hoses to length. I did not feel smart at that moment.
