LS Swap into 2010 SHO
StealBlueSHO
Administrator
Staff member
NoVA Speedshop out here in VA is interested in doing an LS swap into my SHO...we are talking full drive train swap along with a stand alone ECU plus fabrication to get it all to fit...  I am very tempted... thoughts?
Currently working on a ROM for costs with them...
A Taurus Stingray project?  I guess anthing is possible given time and money.
Although, I would not do this to a SHO.  A regular Taurus, sure.
Honestly to make that swap worth it i feel like you'd have to be looking at one of the supercharged variations of the LS series. LSA or LS9 most likely.
I just don't think it would be worth it to spend all that money to swap in a NA LS motor and be making AT MOST 500hp at the crank(via an LS7). You might be making more crank HP right now on your current setup.
Of course the flip side of it is . . . if you really have the funds to modify an LS motor then the power possibilities are endless and you would have a cool one off "SHO".
Although right off the bat i think the $ vs power potential in that swap wouldn't make it worth it for me personally.
So that will render the instrument cluster useless and traction control button?
The rear suspension and axle would need re-engineered?
I would think the LS would need a blower to run with what you have
I say don’t do it..
Every electronic do dad runs through your ecu I would only use a stand alone for something that has little option for a good tuning solution
OMFG!  Not another LS junkie.  Geez see enough of them on FB.  Do a Coyote/6sp auto swap.  Im sure you could almost swap a mustang rear subframe onto a SHO with some work.  The front eould be the hardest.
LS swap?
Ho hum. Yawn.
Not worth the effort.
Besides, one shouldn't taint the platform with such a power plant. It's a SHO. Respect it for what it is. Including it's heritage.
Go poo poo on a different model/make.
bpd1151 said:
LS swap?
Ho hum. Yawn.
Tell me how you really feel...
Honestly... the ONLY heritage the Gen 4/4.5 has with the first 3 generation is the name... otherwise its a completely different car. Not trying to start an argument just pointing out the obvious. Last I checked there isn't even a bolt in this car manufactured by Yamaha.
Additionally, before everyone goes completely ape sh!t, this idea was brought to me... the LS motors are respectable motors in their own right. No need to "poo poo" on anything.
Lol I actually hate the LS engines...what ever the opposite of a technological gem is that’s what the LS is.....low revving, single cam, low compression, boring....I know there are modified high rev, high cp but I’m talking about the average LS
I appreciate SBS bringing this Topic up for Discussion! New ideas and thoughts should always be welcomed.  Z  :)
Well, you did ask for opinions, and those who know me well, do know that I don't sugar coat things.
But I am glad to see no offense was taken, because none was intended. But it was/is merely my opinion.
Seems plenty of others are steering you clear from such an adventure as well. Just in a more subtle manner.
I am glad to see though, that this ****-a-manie idea was not initiated by you, but merely presented to you as an idea.
You get kudo points for that! LOL.
Heed the communities advice. That's all.
Love you. Smoochies.
Well anything is possible, all it takes it money.  You could absolutely build it to retain functionality of all your factory instrument cluster and electronics.  Flyin Miata does it all the time with the LS swapped Miatas.  It's just not a plug-n-play solution.  It just takes more money to make it work.  So if that's something you really want, and have the cash for, then there's nothing holding you back.  A V8 rear wheel drive SHO sounds awesome, and it may seem more like what you would expect from the factory in a sport sedan.
The Coyote swap would be cooler, sure.  It would also be more expensive, and longer development time.  LS swaps are way more common, so it would be quicker and easier to get sorted.  If you do swap for an LS, then you can start with a base motor and once you get the swap done, mod the motor to your taste.  The LS aftermarket is bottomless.  You will never run out of things to make you go faster.
Personally, my 2 cents is this:  Take the money that it would cost to swap, and put it into getting a custom, fully built transmission and PTU for your existing drive train.  Once those parts can handle higher power levels, you can start extracting some real power from the EcoBoost.  You could go for a legit "big turbo" set up.  Have some custom exhaust manifolds, hotpipes, and downpipes made, and throw some insane sized turbos on the car.  Go REALLLY crazy and be the first guy to do a monster SINGLE turbo SHO.  Then smash BPD's record at the drag strip.  Which will make him start chasing bigger numbers, and all the new parts that come out of it will trickle down to us peasants, lol.
So yeah, if your heart is really set on an LS, and you have the money and the patience, go for it.  I just think it'd be way cooler to break through the current performance plateau the SHO platform has been sitting on.
I know it's unrelated to the Topic but would invest in getting a newer SHO IMHO or something similar depending on your budget and unfortunately our vehicles are not getting any newer and loosing value as the years go by!
Best of luck my friend!  Z
If you want an LS swapped car, just buy a foxbody roller and throw an LS in that. I cant see any reason to throw an LS into a perfectly running SHO, and spend probably half the value of the car to swap to the LS, especially with the amount of mods you've done that would need to be repurposed or go to waste.
In a non SHO model, maybe, but in a SHO, I say no. You want an LS car, go get an SS instead and spare the SHO.
