derfdog15 said:If you want an LS swapped car, just buy a foxbody roller and throw an LS in that. I cant see any reason to throw an LS into a perfectly running SHO, and spend probably half the value of the car to swap to the LS, especially with the amount of mods you've done that would need to be repurposed or go to waste.
In a non SHO model, maybe, but in a SHO, I say no. You want an LS car, go get an SS instead and spare the SHO.
Half the value of the car?....id say it would be double the value of his sho if not more....parts labor and yes there will be fab oh yes there will be fab
I'm with derf....You want an LS I'd get a Pontiac G8 and mod it or an SS and mod that because once you LS swap a SHO you would lose the FWD and you'd essentially have a G8 or SS anyway.
And good luck getting your gauges to work..I know there are companies that make wiring harness' for engine swaps but those are for popular swaps....With the high speed CAN BUS and all the body modules I say good luck with all of that..You'd be finding things that don't work constantly....ANd how about DBW? You'd need a pedal assembly from a DBW LS engine or go cable throttle and if you used a GM ECU the rest of SHO's electronic controls are screwed
