Massage seats
FearlessAZ
So, I was driving the other day with my wife and after about 20 minutes, she mentioned the seat had felt funny since we started driving. She said it felt lumpy and that it almost felt like she was sitting on rocks. I checked it out and can confirm what she said. It almost feels like sitting on partial golf balls. When I tried cycling the bottom massage on and off, I couldnt feel a difference. And the back massage didn't seem noticeable. Is it possible that some of the air bladders got stuck on inflate? Anything that I can do about this issue myself or am I looking at a dealership service? I've also noticed that my drivers side seat tends to randomly inflate a bit. I think I can get both of them covered under the extended service warranty but was curious if it was something small or a Pita.
Pulling fuse 35 in the passenger compartment fuse panel (Smart Junction Box) may or may not make a difference.  That fuse controls a lot of things, including the camera, AWD module, Parking Aid module, etc.  Some very noticeable stuff.  So my guess is replacement of the lumbar/massaging component is the true solution.
A couple of threads that may give you insight on MultiContoured seats:
http://www.ecoboostperformanceforum.com/index.php/topic,932
http://www.ecoboostperformanceforum.com/index.php/topic,2232
How it's supposed to work
Item  Description
1  Massage control button
2  Lumbar air bladder control button
3  Seat track control button
4  Recline control button
Push button 1:
[list type=decimal]
[*]forward for cushion massage or rearward for backrest massage
[*]either way to turn off the massage
[/list]
Push button 2:
[list type=decimal]
[*]up or down to select top, middle or bottom lumbar air bladder
[*]forward to inflate or rearward to deflate a lumbar air bladder; hold the button until the desired pressure is reached (each bladder must be selected and inflated/deflated individually)
[*]forward or rearward while the cushion or backrest massage is on and the massage will turn off
[/list]
Push button 3:
[list type=decimal]
[*]in any of 6 positions to adjust the seat track
[/list]
Push button 4:
[list type=decimal]
[*]forward or rearward to adjust the backrest
[/list]
When massage is selected, 1 bladder at a time inflates and deflates in the backrest or cushion. The backrest and cushion massage cannot operate at the same time. Backrest or cushion massage times out after 20 minutes.
When the backrest massage is turned off, the lumbar control will default to the middle bladder. If unsure which bladder is being controlled, 2 pushes up or down will always select the top or bottom bladder. The lumbar bladders can hold pressure while the cushion massage is on. After turning the backrest massage off, the pressure in each of the lumbar bladders will automatically return to their previous pressures before the massage was turned on, as long as voltage and ground remain at the module. Lumbar pressures will automatically reset after temperature fluctuations or when the vehicle has been turned off for a while.
When the backrest or cushion massage is on and the engine is turned off, the system will turn off and the module will not bleed off pressure in the bladders that are inflated. When the vehicle is turned on again, the Electronic Control Unit (ECU) defaults to off and deflates all bladders that were being used in the previous massage cycle. If the backrest massage was on when the engine was turned off, the pressure in each of the lumbar bladders will automatically return to their previous pressures before the massage was turned on.
When the cushion massage is turned off with the seat control switch, the bladders will deflate. The cushion bladders cannot be selected to hold pressure individually like the backrest bladders.
https://secure.revolutionparts.com/levittown-ford/auto-parts/2010/ford/taurus/sho-trim/3-5l-v6-gas-engine/body-cat/driver-seat-components-scat
16's are different as you can adjust/control from the center display with Sync 3.
Yup, I was talking to my buddy who has a 2016 Platinum F150 and he said the same thing. Looks like it will be better to just take it to a dealership and pay the $100 deductible to get them both serviced. Just hoping it doesn't take a couple of days to fix.
