ddlopes said:Well I took the car out this morning for work and again I had the engine light flashing then go off while driving. This happen after I went WOT on the highway. Seemed to have a very small hesitation then pulled good. I'm not seeing any knock at all. I'm starting to think it may be a fuel injector. Or possibly the octane booster may have damaged an O2 sensor. I'll check the codes when I get home to see what comes up. Thanks for looking...
TopherSho said:ddlopes said:Well I took the car out this morning for work and again I had the engine light flashing then go off while driving. This happen after I went WOT on the highway. Seemed to have a very small hesitation then pulled good. I'm not seeing any knock at all. I'm starting to think it may be a fuel injector. Or possibly the octane booster may have damaged an O2 sensor. I'll check the codes when I get home to see what comes up. Thanks for looking...
Do you have a non-meth tun to run on your hardware? if so drop down to that and put it in manual shift mode and do a 3rd gear sweep from 2500-6000 rpm and check the STFT .. it should be obvious at that point. Gluck
ZSHO said:How many miles on your SHO! The sputtering sounds more like an (COP) ignition harness connector issue IMO!
I would double check the connectors to verify that there fully seated and the (red tab) snap into place.
I would also check Spark resistance with a multimeter to verify concern..
There are 2 Front wide-band 02 sensors which should be replaced in pairs and have the same part numbers.
I believe the Fault code needs to be set for at least 3 consecutive times before a code will be emmitted IIRC. Z
ZSHO said:I believe the Fault code needs to be set for at least 3 consecutive times before a code will be emmitted IIRC. Z
TopherSho said:if you did not replace your cats with the new block, you can likely expect some reduced life from the goop.. on the other high low flow cats yield good gains
TopherSho said:Im betting on an erratic O2 reading ..
SHOdded said:yeah the widebands control a/f ratios. the narrowbands are there for catalyst monitoring.
ZSHO said:Did you ever have the FPCM recall performed ? Z
https://drive.google.com/file/d/0B8JUL90DXgdiaWxocmdhUnEteTdQbmdTbDJzU3BKLXpFZzQw/view?usp=drivesdk
