Hey guys,
Long story short I replaced my fuel injectors and cooling fan recently.
Car ran fine for about 10 miles and started to act up after that.
Car runs terrible and has the codes :
P0642 (5V Sensor Reference Circuit Low)
P0236 (Turbo Boost Sensor Circuit Range)
P0193 (Fuel Rail Pressure Sensor Circuit High)
Those sensors share the same 5V reference circuit from the PCM and the circuit is only reading .5V with all the sensors unplugged.
The wiring harness continuity tested fine with ECM unplugged. I’ve come to the conclusion that I need a new ECU.
Do you agree with the above and if so, can I reprogram the replacement ECU myself with FORScan? What about the keys? Also, will my Livernois X3 tune download after the swap?
