I’m having an issue with my STFT’s reading .88-.90 even though I’m spraying 504ml’s of 100 % methanol. I initially thought my Snow Performance pump was the issue since its 4 years old. So I replaced it with a new Snow performance pump that has 300 psi compared to the 220 psi the old pump had. Unfortunately the new pump didn’t help my STFT’s. I’m still only seeing .88 and for the amount of methanol I’m spraying I should be in the low 80’s or possibly even high 70’s. Now the rest of the log looks good from what I can tell. I’ve got zero knock and my IAT2 are dropping 40 degrees once I start spraying meth. I was having a fuel pressure dip but that issue has been resolved and the fuel pressure is good now. Boost seems to be holding steady at around 16psi without any issues. So now I’m trying to see why my STFT’s won’t drop lower than .88 when I’m spraying a good amount of methanol. Also I have all braided lines with 4an fittings throughout the whole system. I had enough problems with the push in fittings leaking on me. I did check all the fittings and there appears to be no leaks that I could see. Any advise on what I should check next would be greatly appreciated. Thanks for your time.
