New Sync Update
Go into your iPhone settings, Bluetooth, and find SYNC. Click on the i, info icon on the SYNC, and there you should see an option that states  allow SYNC notification.
Vortech347 said:
Boggus said:
Also, text message from my 6S are coming thru again, sync reads them and alerts me.
How did you get this to work? My 13' won't work with my 5S.  My older version sync (2011) escape does them just fine!
Just checked what you mentioned.  My "show notifications" was in fact turned off!!  If this works you're my hero.
It should, unless you carry bad luck on your back.  :alkashi:
I have yet to test mine, hopefully this weekend.
I think there is also a TSB on this discussion for those of you that are still having issues.  Z    TSB #ASI-45215
NHTSA ID #10058604
Date Announced:
JULY 01 2015
Additional Info:
How to Fix
Summary: FORD/LINCOLN: GLOBAL POSITIONING SATELLITE MODULE (GPSM) NEEDS REPROGRAMMING TO LATEST CALIBRATION DUE TO VOICE PROMPT FAILING TO LOCATING VEHICLE, SCREEN MESSAGE INDICATOR FAULT OF NAVIGATION, INSTEAD OF CURRENT LOCATION INDICATES PREVIOU
Just did the sync update for my 2010 SHO and after it said installation complete I hit the media button and it says media is unavailable, hit the radio button. Says the same thing. So I went to system settings and did a factory reset no same thing. I swear it's one thing after another with this car!
Try removing the ground on the battery for 1 minute,it will reboot(bring up the maintenance screen).  Z
My camera ended up being bad, strange for the timing. Purchased a new camera.
