I thought I'd share my current experiences with nitrous on my Ecoboost V6 so far:
1. I've found that a small dry shot can be accomodated by the computer, if you're running at the limit of your tune then I wouldn't suggest it however if you're running a canned tune and you want to spray a dry shot from what I've seen on the dyno the car will accomodate nicely for the shot. I would suggest spraying at the airbox, nothing more than a 25 or 30 shot.
2. You can spray a wet shot by pulling fuel from the schrader valve under the hood and connecting it directly to the fuel solenoid. Again small shots will work fine with this scenario.
3. If you are at the limit of your stock fuel system adding a dedicated fuel cell will work great. In the SHO/Flex/MKT platform you can create a custom fender mounted intake by buying a 3.5" Airaid UBI setup and pointing the tube into the hole out to the fender making room to mount a 1 gallon fuel cell where the stock airbox used to be. You can even make a bracket that bolted where the stock intake used to bolt to.
4. Any fuel you spray above the commanded AFR in the tune will be pulled by the stock fuel system, I've sprayed fuel only on my nitrous setup and the computer pulled fuel to hit the commanded AFR, 11.4 either with the wet kit firing or without it didn't matter on the dyno.
I am currently spraying a 75 shot on my Flex without any issues, the key to a good kit is the following:
1. TPS sensor - set to 4.5 volts
2. Window switch
3. Fuel pressure safety switch
4. - optional - I would suggest a progressive controller for first gear. There are quite a few out there that contain the window/tps/progressive all in one now for cheap. I am have the following configured:
TPS 4.5V
Window switch - 3200 RPM to 6100 RPM - shift points at 6200 RPM and rev limiter at 6700 RPM
Progressive controller - 35% at 3500 RPM with .8 second delay to 100%
I also used a small import 150 HP wet nitrous kit
2. Window switch
TPS 4.5V
