Victorous Secret
Reaching out to the community to help figure this out. Thank you in advance for all the expertise and advise.
The vehicle is a 2011 Ford Taurus SHO PP with the following mods
3BAR MAP
MD CAI
Catted DPs
2.5" Exhaust
stage 2 WM kit
Custom WM tune
So after a 3rd gear pull on the highway I got off and went to accelerate and noticed something was wrong. The car was lacking power and glanced at the boost gauge and nothing. I am now not able to build any kind of boost. when driving I can hear the turbos working but they sound not as efficient or like clogged, a slight whining sound rather than the spooling sound. Before I was able to build enough boost in neutral to make the BOVs open up, now nothing.
What I have done so far is power-vac the CAC clean, cleaned the MAP sensor, inspected and moved the front BOV to the back, with no luck. I loaded a stock tune and installed the stock 2 BAR MAP. I even replaced the boost control solenoid on the intake manifold since it seamed like a possible culprit and was fairly cheap. Still no luck. I have looked and listened for vacuum/boost leaks by putting it in drive with parking brake and brake and having someone give it gas and didn't find any. Still kinda difficult to hear much unless it is a rather large leak.
What are the chances the turbocharger wastegates have failed? and if one failed would that create low boost or no boost? What is the easiest way to test, or is there a single point of failure for the two wastgates? A recent data log shows them at 0% the majority of the log and only 80-100% for a few seconds. Anyway easy way to dislodge if they are stuck?
What other components would you suggest I look at?
Thanks again
3BAR MAP
MD CAI
Catted DPs
2.5" Exhaust
stage 2 WM kit
Custom WM tune
Thanks again
