Noisemaker Delete
polskifacet
Hey Guys,
Turns out dealer cracked and glued my noisemaker so I decided just to remove it. Please wait for me to confirm fitment before ordering!!!
Parts List:
1-5/8" ID HPS Silicone coupler - $9.43
https://www.amazon.com/gp/product/B0058W7VCU/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
1-5/8" T-Bolt Hose Clamps - $8.13 x2
1.5" Stainless OD Slug/Pipe Cap - $11.85 Shipped
http://www.globalindustrial.com/p/storage/fittings-framing-rail/railing-systems/industries-end-cap-flush-for-15-tubing-satin-stainless-steel
Seems like a simple elegant solution/alternative to a noisemaker delete pipe.
Did you check out siliconeintakes as well? I want to say the T-bolt clamps are about $2 ea. from them.
Let us know how it works out!
I hope i'm wrong but thought it was 1.5 in.!!. Z
Definitely going to look great especially with the Blue silicone hose.
I use HPS because they have most of their inventory on Amazon Prime. I was also happy with the quality.
polskifacet said:
Hey Guys,
Parts List:
1" ID HPS Silicone coupler
https://www.amazon.com/gp/product/B004NYJYH4/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
1" T-Bolt Hose Clamps
https://www.amazon.com/gp/product/B009AG10EK/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
1" Stainless OD Slug/Pipe Cap
http://www.globalindustrial.com/product/itemKey/31191796
Here's my old one..
Measured it better for you. There is a outside rib that I'm sure you know is there and I measured it plus the ID and OD..
Here's the rib
Inside diameter
Outside diameter
One more
And if you want to not worry about it blowing off or not looking stock you can get a PI piece.
this has been holding less than 6 bucks Home Depot. Used a 1 inch cap pvc cut everything down. Not as nice as the setup above but something you can just go to Home Depot for. Tryied the 1 1/2 cap too big blew off.
And no more thud. Also didn't wanna be spraying 100% meth into it
joe raptor said:
Can anyone tell me "what does it do ? " , any significant performance? or ?
Makes noise. Removal just makes less chance for boost leak and less "engine noise" pointed towards the cabin.
Great "Mod" there Adam. :thumb:  The only thing that concerns me is the TB piping"ring"looks a little loose/split. IDK.  Z
polskifacet said:
Perfect fit
How's this holding up?
I found this from the orange box. Going off the measurements in here it should fit and even comes with its own clamp
Looks like that thing from the HD only is good to 4.3psi, darn. Maybe a combo of the Oreilly's plug and the cap to clean it up?
