This is on my tablet but if I get the lockpick then I can throw it to my NAV screen.ajpturbo said:Thats pretty cool...so remind me again...that is on your tablet thing via bluetooth from the obd thing that transmits? Or is it the lock pick thing performed on ur factory screen?
FoMoCoSHO said:You have to learn to program the tuxedo layout if you want to retain speed in DC. If you try to build gauges, you add a translation layer that makes it as slow as Torque.wasinger3000 said:I'll have to see if I can do the same on the iOS version. I like it though, I've been using the MX wi-if with dash command (with ford PID package) and I love how quickly the data is supplied.
Just hate the lack of gauge modification.
I'm learning but it is SLOW and not something most will want to screw with. No matter what I build though, someone won't be happy, lol...
FoMoCoSHO said:The little arrows at the ends of the needles are actually the min/max carrots for the gauges
I used the same pid that can be found in the torque pid thread. One of the pids didn't work so I'm still troubleshooting it.wasinger3000 said:FoMoCoSHO said:The little arrows at the ends of the needles are actually the min/max carrots for the gauges
I like it. What process did you use to add knock?
FoMoCoSHO said:I must've fat fingered something.
What was his name?ajpturbo said:FoMoCoSHO said:I must've fat fingered something.
I fat fingered something on valentines day
FoMoCoSHO said:What was his name?ajpturbo said:FoMoCoSHO said:I must've fat fingered something.
I like shiny lights?ajpturbo said:Fomo i dont know why you bother with pid's, according to lms the pid's are manipulated by the calibrator that writes the tune and the ecu will distort the readings so i dont know what there is to gather from them
FoMoCoSHO said:I used the same pid that can be found in the torque pid thread. One of the pids didn't work so I'm still troubleshooting it.wasinger3000 said:FoMoCoSHO said:The little arrows at the ends of the needles are actually the min/max carrots for the gauges
I get what you are saying about the custom look but it is much more visible, especially at WOT, where it is now.ZSHO said:That sure looks sweet FoMoCo,definetely need to get the lock pick and have it installed on the Navi screen for a nice custom look IMO,took mine apart twice and let me know if more info is needed. Z
